new brake line problem
Discussion in 'The Garage' started by wraenking, Jan 19, 2005.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    ok, when i ordered my lift, they sent me brkae lines for the 1/2 ton, so my banjo bolt for the caliper wont fit through thehole on the brake lines they sent, and if i drill it ou, it would be even with the hole where the brake fluid shoots out.
    biggest one napa carries is 23", and the ones with the lift are 28"
    is 23" enough?
    the other problem is that it looks like the brake lines i got from the lift have a bigger top to them where it connects near the frame? arggggggggggggg
    any other options?
    thanks
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    do not drill it !!!!!!!!!!!!!!! return those line call tim 84k10, he is a vendor here. i bon't think i would go w/ the 23" ones.
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I think that 1/2 ton and 3/4 ton use the same size banjo bolt on the same axles. The banjo bolt difference is between 10 bolt and a D44. Someone will step in if I'm wrong.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    definitely wrong line for the caliper, probably wrong year or axle model im sure
    do some more research make sure of what you really have so you can get right hoses/lines
  5. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    i think it goed but year had the same problem when i swapped axles one time
