New Brake Lines :)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Dec 2, 2000.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    Got my new stainless steel brake lines from pro comp and put the puppies on ... I love them... They work great with a 4 inch lift... Dont need the ugly brackets now... Well worth the 110 bucks!!! They look sharp too...
    Um... yes officer I know it's too big...
  2. mich89k5
    mich89k5 Registered Member
    Oct 30, 2000
    40
    Michigan
    Did(can)you buy them direct from Pro Comp? If not, where did you get them? How quick were they about shipping them. Can you feel any difference as far as the braking response. I'm not totally sold on the idea that it will make that much of a difference over new rubber hoses. What do you think?
    Mich89k5
  3. shum1
    shum1 1/2 ton status
    Oct 8, 2000
    270
    UTAH
    I assume that if I go from stock to 6" lift I'm gonna have to extend my brake lines. Am I correct? Whats the economical way to do this? 100 clams is a little much for me right now. Thanks.
  4. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    I just put the ProComp lines on my '73 about a month ago. It was a bit of a chore, esp on the passenger side front. The newer k5s may be different, but it was a pain to get the nut from the stock brake line inside the framewell to come off. Also, I had to come up with two large washers to prevent the front lines from moving around where they pass through the frame. Luckily I had a couple extra from my old front stabilizer I took off. The rear was easy except a stubborn stock brake line fitting. I was surprised at how much smaller in overal diameter they were over stock. The stock lines must have a very thick rubber covering over them. Oh yeah, on the front where the line attaches to the caliper, the contection wasn't near as stable. The stock had two ears that lock in on the caliper and keep the line from twisting and losening. The ProComps didn't have these. Overall, the fit wasn't what I expected and I didn't notice any difference in braking. If I did it again I would get the longer factory lines to avoid the fitment problems.
    Fencepost eater
