New build
Discussion in 'The Garage' started by zopaintball, Sep 11, 2005.
  1. zopaintball
    zopaintball Newbie
    Sep 9, 2005
    3
    LA
    Hello all,
    I am new to building an actual funtional insteaad of for show 4x4 I have a new vehicle and want it mainly to be for mudding some very few rock outings (That would more be like trail riding type stuff.
    The 4x4 is A 1982 K5 blazer It has a 350 newly rebuilt and new 350 transmission it has no lift of any kind has 33" tires right now everything else is pretty much stock. I would like to run 35'' (To me I think I could do this with just fender cutting ?) I want a winch, replace the shocks(they look aged) The truck drives find no running away or anything but the breaks pull to right, am going to get them looked at. I would like new more reliable guages, Thats everything I can think of I want to replace now what do you guys suggest to be put on it? I would not like to change anything major unless it breaks or I see the need, so please explane why I need what you suggest. I will get some pics of the rig up and show progress should be interesting.
    Use of truck mainly mudding some trail use. Its not a daily driver but is needed for weekend street use.
    Here are some pictures of what I am starting with i have some just and bad repair of rust but am fixing that in the next couple days.
    ZO
    Sorry bout the size
    Thanks ZO
  2. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    dont bother with the brakes....most of the people here have rigs that pull to the right...most dealers wont even look at it. for mudding, i would say some sort of lift to keep your rig from beeing a bull dozer and not getting far. you dont want to be down in the mud, you want to keep as much of the body out of the mud...it will slow you down alot.
  3. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    I must TOTALLY disagree with that. You must not overlook one of the most important safety issues.
    If it does anything besides go straight, there is either something wrong with steering, brakes, or suspension. Most likely it is a collapsed brake line or a hanging caliper, but don't just ignore it!
  4. zopaintball
    zopaintball Newbie
    Sep 9, 2005
    3
    LA
    I will be getting them looked at but what are some the most needed to the least needed things I should get for the build?
    ZO
  5. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    I would just replace the left side caliper and when you do the lift replace the lines. A 6" would prolly be best to keep you high and dry in the mud. For the winch your gonna need a new bumper so look around here and you'll be able to find one. ORD could hook you up with just about all you need.
  6. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    If you're heavy on the throttle you might want to consider dumping your stock 10B rear for a 14BSF or better yet a 14BFF, but most people will probably say you're alright up to 35's with a 10B. Also, 6" lift will probably mean you'd need a lengthened driveshaft, with 4" some people can stay stock, others needed longer, just depends on the rig. This is all stuff I've learned from others, not my own application. If you want more ideas of what to buildup and where to get it I have all my plans on my website. Most of my research of what to get and where is from searching past threads on this site. My Plans It's for a burb, but most is applicable to Blazers, too.
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    note to self: never wheel with Psychotic Dead Guys, they drive death traps. if you're going to pick something to overlook on your rig, make it anything but brakes and steering.
  8. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Fix the brakes, replace the shocks. Get a 4" lift and avoid most of the problems with a larger lift. Trim the fenders as necessary. Wheel it.
  9. zopaintball
    zopaintball Newbie
    Sep 9, 2005
    3
    LA
    Thanks for the feedback guys I will post some pics on what I am starting with later today and show progress I am hoping to complete everything in about 2 months so it should go pretty fast.
    ZO
  10. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    I agree, you should get your brakes checked, but if nothing is found to be wrong, don't panic. These trucks have a tendency to pull right under heavy breaking due to the push pull type of steering. Compress the springs and the drag link pushes the steering arm slightly back. This cause a slight turn to the right.
  11. PsychoticDeadGuy
    Jan 8, 2005
    753
    i didnt mean overlook it if it is really bad. i have had 2 different dealers look at mine. 1 of them i had to force to check it out because its a problem that most dealers wont even deal with. if it is just a slight pull then you probably wont be able to get rid of it completely...if it is bad, by all means get it fixed.
  12. zopaintball
    zopaintball Newbie
    Sep 9, 2005
    3
    LA
    More pics started a paint kob "rattle can" Yellow/black
    Added Herciliner on the front floor board.
    Was wondering if by the pics can anyone tell if that looks like a stock suspension? Them are 33/12.5 on there right now.
    Thanks ZO
