New bumper project: will it be tough enough?
Discussion in 'The Garage' started by BowtieRed, Jul 13, 2003.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    Ok here's my design for a new front bumper since i smashed the other one on a steel post in a gas station parkin lot. to you think it will be strong enough? All welds will have to be oxy-acetelyne /forums/images/graemlins/frown.gif Anyway, that's the frame of the bumper, and then it will be covered in 1/4" steel plating, possibly diamond if i can't find any steel diamond plating.
  2. Grim-Reaper
    7,385
    Atlanta
    Yeah it's going to be strong if you build lit like that. It's also going to weight 400lb.
    Idealy the bumber would fail before the frame.
    1/4 plate if you build a box out of it is major strong. Correct design that's all you would need. My bumper is 3/4 side plates bolted to the frame. Reason is they also have the Clevis holes in those plates. My front bumper is 1/4 plate to form the winch deck and lower skid. The ends are 4x4 box (3/16 wall) that also form air tanks. It weighs 80lb. Rear bumper is built the same way but the center plate is 3/16.
