new cam, backfires thru intake
Discussion in 'The Garage' started by 89Burben, Mar 26, 2006.
  1. 89Burben
    89Burben Registered Member
    Jan 3, 2005
    98
    CT
    i just installed a comp cam, with new lifters and whatnot in my tbi 454. I am in the break in procedure and the truck was running good when i first started it up, and after about 10 minutes of running, when holding the rpms steady at 2000 rpm, it would run smooth, then there would be a slight vibration for about 5 seconds then go back to smooth, almost like a plug wire grounding out, but i dont think it was that bad of a vibration to be on 7 cylinders.....
    the other problem is that you cannot rev the truck up abruptly or it will backfire through the intake somtimes. i have new plugs and wires. the distributor is fairly new along with the cap and rotor. the timing is set at base or zero. grounds seem ok and im getting enough fuel pressure. the heads were just redone.
    there seems to be a little valvetrain noise. when i adjusted the rockers they were adjusted when the lifters were not pumped up or filled with oil. they were new.
    I used the turning of the pushrod method then when there is a drag felt, crank the nut down 3/4 of a turn. do they need to be re-adjusted now that they are pumped up? thats all i can think of........
    thanks
    brian
  2. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    I would say yes, redo your valve lash now that the lifters are pumped up. I don't know if that is causing your problems though.
  3. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    Check your timing.
  4. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    valve lash
  5. ryoken
    Jun 13, 2003
    29,621
    1,366
    Jersey Shore
    ditto... :D
  6. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    adjust those suckers
  7. 89Burben
    Jan 3, 2005
    98
    CT
    alrighty i adjusted them, and checked my timing which seems to be good. when i first started it up it sounded good. (no noises and no backfiring) after about i minute of running it you can now hear noise coming from the valve covers again but no backfiring. do they need to be re-adjusted??? or do i have a bad lifter???
    another problem that it seems to have is at a steady 2000 rpm it will intermittently drop about 100 rpms and the truck will shake a little, then go back to 2000 rpm and back and fourth.....the wires, cap, rotor are new...
  8. 89Burben
    Jan 3, 2005
    98
    CT
    well i just started it up again tonight and its not popping through the intake anymore i think that was a timing issue.
    i changed the oil for the first time and there was microscopic metal dust that looks somewhat like the mettallic that is added in automotive paint. i believe that there would be much more if a lobe on the cam was worn off.
    As far as my valvetrain noise problems go i have a distinct ticking coming from the passenger side bank of cylinders, that ticks about as fast as the timing flash on the timing gun.
    currently i have 87 inthe tank. i have new heads that yield about 9.2:1 compression.....should i be running a higher octane?? or is my problem with a lifter/lobe/or rocker....
  9. damewood
    damewood Registered Member
    Oct 6, 2005
    9
    WV
    that almost sounds like a lobe wearing if it persists take your valve cover off and check your push rod travel u should be able to tell that way
  10. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    normal break in of a cam will cause a slight metallic look to the oil, but you have to look REAL close. from what you described, that cam is junk.
  11. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    I am thinking you adjusted your valves to tight, when you turned them 3/4 of a turn. That was too much for when the lifters filled with oil, which caused valves to hang open during the compression stroke. That is why it popped out the TBI. I have tried both pre-filling lifters before installing them, and installing them dry. It is really a matter of preference, but I have found I like installing them dry because I get a better feel for when the pushrod is seated against the lifters with my fingers. If the lifters are pre-filled, then the lifter tends bleed down when the pushrod is tightened down to it...making it hard to get a feel for the proper pushrod tension. When I adjust my valves...first, with the lifter on the low side of the cam lobe, I use the push rod spin method, just until I get enough drag on the push rod that I cannot spin them easily anymore with my fingers. Then I turn the rocker arm adjusting nut only 1/4 of a turn more, which allows enough slack for the lifters to pump up with oil. I may not prefer pre-oiling my lifters, but I am a big fan of pre-oiling the engine before its initial start. I am also a big fan of running valve adjustments on a Chevy engine, after I have completed initial fire up and a little break in time.
  12. 89Burben
    Jan 3, 2005
    98
    CT
    ok, i reved the truck up to higher rpms about 3000 and the ticking got faster and it popped a little thru the tbi...
  13. 89Burben
    Jan 3, 2005
    98
    CT
    i adjusted the valves when the lifters werent pumped up they were new. i also did use the twist between your fingers method, but i turned them down 3/4 of a turn according to the haynes method. i readjusted them yesturday and used the firing order method and turning the crank 90 degrees and cranked them down to 1/2 and this was after running the truck for a while.....so im assuming the lifters are pumped up.........should it be a 1/4 you are saying?? is this when the lifters are pumped up or not??
  14. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    my father has been a mechanic for 45+ years.. he just helped me do mine... now I dont know if a 454 is different....but I believe he even checked my chiltons manual and was like.. wow they tell you to do this too.....
    with #1 @ Top Dead Center - they tell you what valves to tighten... my father had me tighten them until there was 0 play... then loosen until you can move the pushrod.... then snug till play goes away.... then 4 x 1/4 turns..... yes 1/4 turn increments and 4 of them.... we did that last time we took my heads off and it was perfect then we did it this time and it is good again.....
    the manual then said I believe.... #6 @ TDC and which valves are left.....
    my truck just popped through the intake but that was timing was retarted real bad....... too low.... hope some of that info is useful if not.... sorry :crazy:
  15. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Are you running a proper TBI cam? If you have one particular 'tick' it can only be lobe, lifter, rod end damage, rocker/pivot ball, sticking valve, valve spring or valve seat problem.
    Find out which one is ticking. (put oil deflecter clips on the rockers if you can get them and run it with the cover off to listen to each one with a screwdriver to your ear). Then start at one end of the 'train' and use a process of illimination. Measure lobe lift, if that's good pull the rocker and check the push rod ends, rocker and pivot ball etc.
  16. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    If you look at a factory GM shop manual, they will say turn the adjusting nut 1 full turn, but I guess a number of techs outside of GM felt this was too much, which is why you will see Haynes and Chiltons manuals list 3/4 turn instead.
    The whole Chevy valve adjustment topic, has always been a hotley debated subject. I have read entire articles in Car Craft and Muscle Car magazine devoted just to this subject of valve adjustments on a Chevy engine. A lot of experianced Chevy engine builders have developed their own favorite method for doing this (like I have). I feel sorry for any rookie that ever posts asking opinions on how to do this because you are going to get so many different answers, that you will be more confused after you read the opinions, then when you first started.
  17. big454blockchevy
    big454blockchevy Registered Member Premium Member
    Mar 26, 2006
    53
    el paso
    Hopefully it's not a bent valve .
  18. 89Burben
    Jan 3, 2005
    98
    CT
    well i took off the passenger side valve cover and took a long piece of wood and put it onto the rocker stud and listened. i found a few rockers to be loose. i adjusted them while it was running and to my supirze not alot of oil came out at all like i had imagined. From what other ppl were saying i was predicting a gizer, yet it was more liek a seeping outa the holes. anyways now that they were adjusted i shut the truck off to put on the valve cover and now the starter clicks when i key it :mad: ..........thanks to advanced auto:rolleyes:
  19. ryoken
    Jun 13, 2003
    29,621
    1,366
    Jersey Shore
    I'd be pulling that intake to peek at those cam lobes at this point...
  20. chevyk2500hd
    chevyk2500hd 1/2 ton status
    Nov 24, 2005
    192
    Lafayette, Indiana
    When I did my 383 swap on the truck mine would also shot flames out the intake. After i added bigger injectors and a new custom chip the problem went away. I would be willing to say your buildup is alright and the computer just doesn't understand.
