new carb - dieseling
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by K5Buckeye, Sep 10, 2001.
  1. K5Buckeye
    K5Buckeye Registered Member
    Mar 5, 2001
    75
    WA
    Replaced the old q-jet w/a brand new edelbrock q-jet, 1901. It's dieseling. Why? It didn't do it b/4. Please advise.
    Thanks.
    1972 K5
    1991 Jimmy
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    you sure you hooked up your vacuum advance in the correct place???
    check that first, i am sure others will coment. I have a Q-jet 1901 aswell and i had no problems. hate for it to get a bad rap...
    ARQ.
    1-72 4x4 CST Blazer
    2-71 4x4 CST Blazer
  3. ErikH
    ErikH 1/2 ton status
    May 15, 2001
    112
    Southern California
    If you disconnected the plug wires, make sure they're back in the same order. Dieseling is often a timing issue. Similarly, if you replaced the intake manifold, make sure the replaced distributor isn't off by a couple teeth.
    Erik
  4. K5Buckeye
    Mar 5, 2001
    75
    WA
    Thanks for the tips. I'm pretty sure I did all that stuff. I'll double check though.
    1972 K5
    1991 Jimmy
  5. Klef72K5
    Klef72K5 1/2 ton status
    Apr 8, 2001
    249
    Columbia City, Indiana
    did you turn your distributor? Sounds like you have it retarded.
    <a target="_blank" href=http://wsphotofews.excite.com/031/rw/Jo/og/t488200.jpg>http://wsphotofews.excite.com/031/rw/Jo/og/t488200.jpg</a>
  6. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Depending on the camming you're running, you might need to alter the jetting or power piston setting. No out of the box carburetor is going to work perfectly on every engine combination.
