new carpet
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazing86, Aug 13, 2001.
  1. blazing86
    blazing86 1/2 ton status
    Dec 24, 2000
    290
    anyone klnow where to buy new carpet, or would it be better just to buy carpet and cut it myself?
  2. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    LMC truck, JC Whitney, etc.
    I tried the cut your own thing, and it didnt come out very good.
  3. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    I bought mine through JCWhittneys about 3years ago and it's held up great. It came molded for the tranny hump and everything.
    That's the drawback of cutting it yourself. You won't get a good fit around the hump and wheel wells.
    <font color=blue>Esteban</font color=blue>
    <font color=red>HAVE YOU EVER HEARD OF CHATA?
  4. Cusm
    Cusm 1/2 ton status
    Feb 25, 2000
    360
    OK
    Use a company called ASC(or it might be ACS, I will verify) or ACC. They are about the best companies out there and LMC and others use one of the two for most of thier stuff. I always liked to cut out the middleman to save some $$. I think ASC is cheaper. My uncle has an upolstry shop and uses them when he uses premolded stuff. He says to go w/ ASC.
    Good lord. The rod up that man's butt must have a rod up it's butt.
  5. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Auto Custom Carpets(ACC) in Aniston Alabama make the best reproduction molded carpet for our trucks IMHO.
    '85 K5 : Run it til it breaks, then fix it and go again!
  6. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Go to a local auto trim shop. They have numerous sources and you can see what you are buying, feel it and match the color you want. When I replaced my carpet I also bought enough carpet to do my custom side panels, it all matches.
    Derf00
    "A WISE MONKEY NEVER MONKEYS WITH ANOTHER MONKEY'S MONKEY."
  7. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I got mine from Auto Custom Carpets <a target="_blank" href=http://www.accmats.com>www.accmats.com</a>
    ~~'84 K5~~
    Check it out at:
    <a target="_blank" href=http://www.k5.rockcrawler.com>www.k5.rockcrawler.com</a>
  8. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I did both and saved some money along the way. I think it would be impossible to cut carpet for the front, because it doesn't lay flat so I ordered a custom fitted rubber mat that covers up every inch the carpet used to. $55
    For the rear, since it is flat, I got a big slab of black carpet from an outlet store here for $10, and cut it myself. It took a while, but looks good and was dirt cheap.
    $65 is way better than giving LMC or JC Whitney $250!
    '73 K5
    Chevy good...Ford bad
