New center console/beverage center (pics)
Discussion in 'The Garage' started by mciahpv, Nov 27, 2005.
  1. mciahpv
    mciahpv Registered Member
    Jul 8, 2005
    97
    Gator Country
    A while back, I Herculined my interior and got new seats. During that process, I did away with my old center console and eventually filled that space with an Art Carr shifter. The set up looked and worked fine, except that it left me nowhere to store anything, which resulted in lots of small stuff rolling around all over the place. It also did away with the only cup holders I had, which seems pretty petty and bling until you find yourself attempting to pilot 6000 pounds of American pride with one hand while checking in with the better half on the cell phone and your favorite trail beverage (adult or otherwise) nestled uncomfortably against the family jewels. Time for a new plan.
    So I picked up this new F-150 console on ebay and did some special modifications. (Insert Ford joke here) It was more of a PITA than I ever would've thought, but I'm very pleased with the results. Just got it finished tonight. Here's the walkthrough...
    1 -- Had to assemble it in place in order to make it work. Here's the frame bolted in place. The red circle indicates where I predrilled two holes where I would eventually bolt down the shifter legs.
    2 -- Here's where I slotted the bottom to feed the Morse cable through. (You can see it poking through the floorboard.) It's not pretty, but it won't show, so I didn't waste a lot of time.
    3 -- The armrest and actual storage space. I had to dremel out a space for the shifter legs to poke through, they were about 2" too long otherwise.
    4 -- Drilling a hole in the bottom of the console for the Morse cable. This would actually be visible when looking down into the box, so I was very careful with the measuring and drilling.
    5 -- The center setting loosely in the frame with the Morse cable fed through.
    Hang on, have to post another message with the finished pics...
  2. mciahpv
    Jul 8, 2005
    97
    Gator Country
    Here's the rest...
    6 -- The center bolted to the frame with the cable and shifter installed.
    7 and 8 -- Finished product.
    9 -- It was originally plumbed to run A/C out vents in the rear. Since I don't have A/C, I put two LED lights in the vent holes and wired them to my interior light switch. Helps throw a little more light in the back.
    It was way more work than I had originally anticipated, but I'm really happy with how it turned out...
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    That is cool. How hard is it to get to the cup holders while driving?
    They look too far to the back
  4. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    who need them, their for the back seat. theres already 2 next to the shifter...
  5. readymix
    May 30, 2004
    6,706
    26
    Duh.....Since i own a LB truck i always forget about the back seat:doah:
  6. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Looks sharp. What did that new bodystyle console go for on ebay? If you want I can send you some black abs fill the gap around the shifter. It is super easy to work with and if you have a propane torch you can bend it to the same contour as the console.
  7. mciahpv
    Jul 8, 2005
    97
    Gator Country
    Got the console for $100 on ebay. As far as I know, these are from both '04 and '05 F-150s. They call it the "flow-through console." You could probably find them cheaper, but I was looking for black, so I jumped on this one. (It was actually black w/silver top, but I painted the top pieces with plasti-kote while it was apart)
    Thanks for the offer of the ABS -- you can't really see in the picture, but I cut a piece of lexan that is actually sandwiched between the underside of the console and the body of the shifting mechanism. (I forgot to take pictures when I was doing that part) It's sort of a light smoke color, so I may eventually put a green light down in there to match the rest of the dash/interior lighting at night. The gap was one of the hurdles along the way. I didn't anticipate that it would be so big. Thought I would have to enlarge it for the gate shifter and that then everything would be hidden. Whoops!
  8. mayerichm
    mayerichm Registered Member
    Aug 9, 2005
    15
    Oklahoma
    Where can someone find that abs at anyways? I stumbled across some once upon a time at a garage sale and haven't seen any since, it's as useful as duct tape when fabbing stuff.
  9. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Looks great, very clean job.
    I love those seats, what are they? Corbeau's?
  10. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    No problems. Couldn't see the lexan in the pictures (I know see the reflextion of the shifter in it). Did the skull shifter come from ebay? I have looked at a couple like that on there. 100.00 doesn't seem bad at all. I have sold some factory consoles on there for MUCH more then that. I am still drooling over the seats in your rig. Those are smokin :D
    Try any local car audio specialist. I keep it instock at my shop and would be happy to ship some out. I get mine from AAMP of America. I know Select Products sells to the public but their prices are high :crazy:
    It is listed under abs here https://selectproducts.com/html/frame2/frames2.htm
    The only time I use select products ABS is when I need a woodgrain. Theirs is top notch. The black abs is the same as I get from AAMP
  11. RubberFloorMat
    RubberFloorMat 1/2 ton status Premium Member
    Dec 12, 2004
    399
    46
    Oklahoma
    f-n sweet!!!
  12. mciahpv
    Jul 8, 2005
    97
    Gator Country
    Thanks, guys. Making the effort all the more sweet. The seats are Beard/Red Arts. I've got a back seat on order with them too, I'll post some pics when I get it in.
    I actually got the skull shifter at the local Advance Auto Parts. $15 I think, and the eyes light up. Bonus!
