New coil, same old problems...Fixed!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by angrysnowplow, Apr 15, 2003.
  1. angrysnowplow
    angrysnowplow 1/2 ton status
    Jan 8, 2002
    502
    MA
    This is on my '90 TBI 350. Ignition module was replaced because it had the same symptoms as last time. Made no difference. It wasn't getting any spark, I tested the coil w/ an ohmmeter, it was bad. With the new coil, it fired right up, but soon started with the same stuff as before. Runs crazy rich (blows black), dies with any decent amount of throttle (especially from a standstill) and then doesn't want to start back up. I'm at my wit's end here, any ideas? /forums/images/graemlins/1zhelp.gif
    *Turns out it was the map sensor, runs great now. Thanks everybody for helping /forums/images/graemlins/thumb.gif
  2. bee32
    bee32 1/2 ton status
    Aug 6, 2001
    401
    Virginia Beach Va.
    Re: New coil, same old problems
    Didja check yer timing??? Just a thaught.
  3. ratchetmaster
    ratchetmaster Registered Member
    Mar 26, 2003
    47
    PLEASANT GROVE, UTAH U.S.A.
    Does the 90 have a throttle position sensor??
    if so, could be the problem. Or a bad O2 sensor . . . thinks it needs more fuel but doesn't so it is running it rich.
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    vacuum leak maybe? spray carb cleaner around the gaskets and see what happens
  5. angrysnowplow
    Jan 8, 2002
    502
    MA
    I forgot to mention that all those gaskets are new- I had the heads off a little while ago...but do you think a vacuum leak could be so bad as to keep it from starting?
  6. angrysnowplow
    Jan 8, 2002
    502
    MA
    I believe it does have the throttle position sensor..
    A mechanic recommended trying to start it with my foot to the floor- says it will make the computer recognize that it's flooding and stop fueling it... didn't help. I still think it's an electrical thing tho... don't mind me, just thinking out loud. /forums/images/graemlins/ignore.gif
    The O2 sensor is a suspect at this point- the wire ended up getting cut while removing the manifolds (hey, what are friends for /forums/images/graemlins/tongue.gif)I put it back together with a crimp connector.
    Thanks for everyone's input so far. /forums/images/graemlins/thumb.gif
  7. RockyRider13
    RockyRider13 1/2 ton status
    Jul 11, 2001
    102
    Kansas
    I believe that it is either the thirdgen.com or some other f-body website that has the TPS adjusting procedure. The computer could be thinking that you are giving it some pedal when you aren't. I would rule out the 02 sensor because it doesn't give the computer input until the car is warm (closed loop). When it runs, does it throw any codes?
  8. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    Just a thought. did you check your MAF sensor. That will cause it to run rich.
    Colin
  9. angrysnowplow
    Jan 8, 2002
    502
    MA
    mass airflow sensor? I'm not even sure if I have one of those /forums/images/graemlins/eek.gif Hafta consult the Chilton book.
  10. angrysnowplow
    Jan 8, 2002
    502
    MA
    Cool, I'll check out that thirdgen site for fuel injection stuff. Check engine light's been on, still trying to figure out how to read codes with a paper clip.
  11. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    I might be missing something but here's a couple of thoughts:
    1) If it is over fueling and won't restart, could the plugs be fuel fouled?
    2) Is the SES light on? If so, did you get the codes?
  12. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    there is also a pickup coil in the distributor that goes out pretty often...wouldnt be surprised if thats the problem.
  13. RockyRider13
    Jul 11, 2001
    102
    Kansas
    Tbi engines do not have a MAF. The chiltons should have the procedure for pulling codes w/ a paper clip. If not, get the "scnner" from auto zone, well worth the $25. Find out the codes, that will give you a better idea of what the computer is "thinking" before blindly throwing parts at it.
  14. angrysnowplow
    Jan 8, 2002
    502
    MA
    I'll look into those things, too. /forums/images/graemlins/thumb.gif
  15. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    bad temperature sensor in the manifold? Mine went bad tellin it the engine was hot so it gave it no gas, urs might be broken and stuck to cold, floodin it out.....
  16. angrysnowplow
    Jan 8, 2002
    502
    MA
    Bump /forums/images/graemlins/k5.gif /forums/images/graemlins/smile.gif
