New Cooling system
Discussion in 'Midwest Region' started by blazer72, Dec 3, 2002.
  1. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    Well as some of you may know the last time I had the Blazer out the water pump drive flange came off letting the fan go though the 5 core rad. braking the water pump of the block generally trashing any part of the cooling system, as this the 2nd time this has happened it was time to change, why it happens is open to input. The new cooling system is a alluminum rad, an electric drive water pump and f body fans. To night in testing the system the stat is opening about ever 8 min. for 2 to 3 min then shuts. outside air is about 55 in the garage or so. The pump has idler pully on it to keep the drive belts running the same path. The road test is after work Friday. /forums/images/graemlins/k5.gif /forums/images/graemlins/cool.gif
  2. Scooter
    Scooter 1/2 ton status
    Nov 18, 2000
    551
    Grandview, Mo.
    Very cool (no pun intended) .. glad to hear you got it all installed. Got pics???? .. I know, I know, I should just stop by and see it.....
  3. blazer72
    Apr 13, 2000
    939
    KCMO
    Or just ansser the phone! /forums/images/graemlins/ears.gif
