New Dash installed (not shaved...) with new gauges and PICS!!
Discussion in 'Interior - Stock & Custom' started by Chevy305, Feb 26, 2007.
  1. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    So like most of us my dash was old, faded, brittle, cracking, and just plain sucked to look at. Some of you may also have noticed in the past pics of my dash that has 2 el cheapo autozone special gauges in there. I also have the idiot lights in my truck and wanted to keep the bottom 2 lights.
    Pics of the old dash setup:
    Continued...
  2. Metrodps
    Metrodps Strange but nice guy Premium Member GMOTM Winner Author
    Jan 4, 2006
    9,727
    109
    earth
    OK where is the information on how you installed them?
    What did you do under the hood?
    What did you do to the lt blue plastic idiot light area?
    What did you do to the plastic (clear face) covering?
    We need step by step and photos of it all!
  3. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    Continued...
    So being that the el cheapo gauges didn't really give me the look, style, and accuracy I am looking for. The temp gauge would read about 145* when its supposed to read 180* at running temp. Also I wanted to add in some more gauges, and I have always been a fan of AutoMeter's styling and quality. So I bought 4 new gauges all 2 1/16 and mechanical: temp, oil pressure, volt, and vacuum. I also got a hold of an awsome condition dash board that is the correct color too, thanks to TomFord :bow:. And also picked up some new speakers to mount under the dash.
    Well unfortunately, my digital camera was in Colorado with my mother while she was on a skii trip, :( so I don't have any action shots just the finished product...
    Before the CK5 "Tech Junkie" Club hounds me, here are pics of the old dash after I took it out:
    Continued...
  4. tomford
    tomford 1/2 ton status Premium Member
    Jan 19, 2006
    921
    7
    New Hampshire
    mmmm red dash and interior... lookin good
  5. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    I decided to go with the AutoMeter Phantom series gauges. I wanted to pick up the tach too, but I don't have the $$ right now so it will come later because it is a much needed upgrade because that sunpro tach is the 4th one I have put in there. They all just fry themselves within a year. Just very poor quality if you ask me.
    Anyway for the installation:
    The AutoMeters are slightly bigger and longer than the other gauges I have in there, so modifiactions had to happen. In order for them to sit correctly in the dash bezel, I had to hack off just about all the back section of gauge hole. Then fitting them into the dash, I removed the red thingy that labels the idiot light, but the gauges are just way too big. So I had to remove the metal piece in the dash that allows the dash lights to reflect off the back of it. I took my metal snips and cut out the whole top section of it where the back of the gauges will fit into. Test fitted, and then still wouldn't fit right. So I took my hack saw and cut into the plastic housing that houses the stock gauge cluster to free up some more room. Those of you with the the idiot lights, the plastic cluster housing will extend out all the way to red face of the idot light. But I believe that those of you with the full instramentation from the factory might not have to modify the cluster housing because it doesn't have these such extensions to keep the light from each idiot light focused through the red face. So... After all the hacking and cutting, the AutoMeters finally fit correctly. :D So in order to run all the wiring and sending units I removed the 2 top light bulbs and sockets and ran it right out the back (watch out for the printed circuit, don't ruin it) and then to its respective location because with the Autometers in place I won't be able to see these idiot lights if they happen to go off, but its not like they worked in the first place which is the whole reason for me originally installing the gauges.
    Ok now for the installation of the gauges out in the dash where the AC vent is located in AC equipt trucks. It was really simple. I traced where the hole already existed in the dash for the AC through the trim that runs the length of the dash. Then centered the gauges and used a hole saw to cut the holes. Then I installed it onto the new dash board from TomFord with new speed nuts from LMC. The gauges fit perfectly in that spot too. No other mods had to be made, just wire them up according to the instructions. :eek1: (thats right I used the instructions)...
    Oh and the vac and oil pressure gauge sending units are a HUGE PIA to set up correctly with no leaks and so that it'll hold pressure or vacuum without popping out of the back of the gauge and spilling oil into your dash bezel.
    Anyway I LOVE the way they came out. My only complaint is that the angle rings I got with the gauges to put on the gauges out on the dash trim so I could see them better, made them stick out WAY too far, I didn't like them so I thought I'd rather lean over slightly to see the gauge than to have them look bad.
    Ok now for the pics of the final product:
    Go CLICKY CLICKY to make bigger and more focused...
  6. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    You're too fast for me! Speedy Gonzalez here...
    Check again... :D
  7. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    Thanks Tom! I really like the new dash it makes the truck seem that much newer... :D :bow: :bow: :bow:
    I hope you like the grill...
  8. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    where did you get that dash? My suburban is red and the dash is horrible.
  9. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    Nice setup... :)
  10. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    Well you'd have to ask TomFord that... :D
  11. tomford
    Jan 19, 2006
    921
    7
    New Hampshire
    it was in my parts truck, so far i have parted out the whole interior, i donno where the dash came from i dont even know if it's original, it is nice just ask glen, no cracks no nothin
  12. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    I'm going to bump this ttt so more people can see... :D
  13. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Looks good man... It'll be nice having accurate gauges too...
    The white face gauges seem to be very popular, personally not my cup-o-tea, but lots of people running them....
  14. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    Oh and if anyone is interested, my old oil pressure gauge is for sale... :deal:
  15. Craig Artzner
    Craig Artzner 3/4 ton status GMOTM Winner
    Dec 16, 2006
    6,843
    Northeast Ohio
    Lookin' good man. Welcome to the "crackless dash" club. We're a small but elite minority...:waytogo:
  16. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    Thanks!
    We should make that a sig club like the "sheetmetal club" or the "Tech Junkies" :D
    But ya I got a picture of the stuff I cut out:
  17. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    when I finally decided I had enough of my cracked dash I just took it out. Ive had a few set backs since then but as soon as I get the parts (there is a thread in the wanted section for and a-pillar hint hint) Im gonna cut the rest of it out and build and aluminum dash with custom gauges.
    good work though, looks good.:wink1:
  18. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    Ya I wanted to go make a custom dash, but I don't quite have the skills or time or tools to do it.
    I liked what someone else did and stripped the foam off a dash and just used the steel backing, I thought that was cool, but I then ran across Tom's dash and I couldn't pass up on it.
  19. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    i used the frame of the original dash, came out ok for me,
    it could be used and made into a really nice dash if some time was put into it
  20. 1990k5fan
    1990k5fan 1/2 ton status
    Jul 7, 2006
    217
    Gilroy, CA
    What are those switches for in your dashboard? Above the A/C?
