new diff cover installed
Discussion in 'The Garage' started by BIGRED74K20, Jan 9, 2006.
  1. BIGRED74K20
    BIGRED74K20 Registered Member
    May 23, 2005
    82
    23
    Northwest
    i just installed this new diff cover last week, and finally got some pics......
  2. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    the cover's not my cup o' tea, but to each his own - i can see how some would enjoy it. however, i'm curious about the shock angles and mounts. can you tell me more?
  3. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    My thoughts exactly
  4. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    cover looks good man, dont mind them.
  5. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Dumb Question-Where's the drain plug??? I don't know much about that model rearend, but I assume it would have a drain plug in the cover.
  6. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    The fill plug is located on the side of the center section. no drain plug.
  7. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    than why are their two NPT plugs on the top of the cover? i would have put on in the center on the bottom,
    but thats just me
    oh and im also intereted in those shock angles.
    LUKE
  8. rdn2blazer
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    i did not even notice that, i didn't really look closely either. good Q, why two on top of cover? makes no sence.
  9. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    It is so you can get oil down both axle tubes to the wheel bearings:D
    Ira
  10. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    and it lets more air escape when filling, most likely you could use one as a vent to if you wanted.
  11. BIGRED74K20
    May 23, 2005
    82
    23
    Northwest
    i bought the 14 bolt which came out of a guys ramcharger so it already had the mounts welded to the axle(now there in more and higher) so i got rid of the staggered setup and went down to the junk yard and found a 80's dodge truck with no bed on it and took out the shock crossmember out of the back. then i had to shorten it by 3.5" to fit in my frame. i went to this is because it articulates better.
  12. BIGRED74K20
    May 23, 2005
    82
    23
    Northwest
    on the upper left side thats the fill plug which is a dipstick for easy reading. on the upper right side is another fitting for a breather or a diff temp sensor. and on the very bottom of the diff, to the left of the very bottom bolt is the drain plug
  13. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
    How much axle wrap do you get with those blocks, big tires without a traction bar?
  14. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Looks very stout! I like that shock mount in the back and have been considering something similar for my rig.
  15. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    that's pretty cool engineering - covers all the bases for sure.
