New disc brake conversion update. pictures added 2/7/07
Discussion in 'Vendor Forum' started by cybrfire, Jan 5, 2006.
  1. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Alot of you guys know that I've been doing some fab work on different brake conversions such as the twin caliper mount, a toyota conversion and so on. Well all of this led to an interesting develpment.
    Here's a picture
    <IMG onmouseover="if(this.width >= 540) {this.style.cursor='pointer';}" onclick="if(this.width >= 540) window.open('http://coloradok5.com/photos/data/500/newbracket.JPG','Image','toolbar=no, directories=no, status=no, menubar=no, scrollbars=no, resizable=yes');" src="http://coloradok5.com/photos/data/500/newbracket.JPG" onload="if(this.width >= 540) {this.alt='Click here to see the orignal image';}" border=0>
    Looks alot like the old one doesn't it? Actually a few differences. We are using a different rotor but the same caliper. What this has allowed us to do is change the spacing that is required by the old kit. The one in the picture has a 1/4" spacer as opposed to the 3/4" spacer (Still a solid ring and not tubes). This means its cheaper to produce and cheaper for you to puchase. An added bonus is the entire kit is more rigid due to the shorter length bolts required. It also affords a great deal of wheel clearance since the entire rotor is set further inboard.
    As of now we are expecting final pricing to be in the $45 - $50 range for the entire kit including hardware. Of course still will be Grade 8 bolts and the same High Alloy Loc washers that we've been using all along.
    And for those of you who I know are going to ask here's an updated photo of the twin caliper mount.
    <IMG onmouseover="if(this.width >= 540) {this.style.cursor='pointer';}" onclick="if(this.width >= 540) window.open('http://coloradok5.com/photos/data/500/twincalipermount3.JPG','Image','toolbar=no, directories=no, status=no, menubar=no, scrollbars=no, resizable=yes');" src="http://coloradok5.com/photos/data/500/twincalipermount3.JPG" onload="if(this.width >= 540) {this.alt='Click here to see the orignal image';}" border=0>
    This is pictured with a 15" wheel!! Plenty of space.
  2. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    What's the difference with the rotors?? Very nice by the way.:D
  3. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    How soon will either system be available?
  4. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    The single caliper kit will be available Monday. It will also come with all the necessary information to obtain the correct rotor from your local auto parts store.
  5. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Hey Kert, will the 1/4" become the standard kit or will we need to request it? In other words will you continue with the 3/4 kit as well.
  6. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    At this time I can't see any reason to continue producing the "3/4" kit. One thing we will be doing is splitting the part numbers between the straight up bolt pattern for use with a chevy caliper and the 45* clocked pattern for rotating the Caddy caliper to get the e brake cable up higher. Or in other words a kit for standard mounting and a kit for clocking the caliper.
  7. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    You're a dually guy :) How about something for duallys and the D70?
  8. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Working on it now.
  9. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    It seems you are working on everything right now. I hope the bed in your shop is comfy.
  10. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    kert... dually d70hd... dual calipers...
    tell me when...
    cam
    ps .. you already painted it in my color of choice... hammered silver!!!
    Ive got that stuff in gallons,,, everything in the shop is that..balck or gray
  11. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    That would imply that he sleeps and I'm pretty sure that he doesn't do much of that:crazy:
  12. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Does the new design single caliper bracket still use the '73-'87('91) caliper? Is the "new" rotor the same thickness? Is the "new" rotor similar in price to the "old" rotor at auto parts stores?
  13. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    It's hard as hell so I don't sleep much anyway!!
  14. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I love that paint. They are coming. What size wheel are you running??
  15. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Same caliper so far. Looking at possibly switching it. Rotor slightly thinner and slightly larger OD. similar pricing on all components except the brackets.
  16. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    What you REALLY need to do is find a way to get a functional e-brake on a setup like that for a decent price. Then I'm interested. :D
  17. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    I agree.
    I wish someone would adapt one of the "drum inside of the disc" type e-brake systems to a 14BFF disc kit. This style of e-brake actually works.
  18. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Not sure what you guys need to pass inspection but we've used a hydraulic valve for ebrakes. Its basically a high pressure inline valve. Mash the pedal and throw the lever and it maintains pressure on the rear portion of the brake system.
    I suppose you need a mechanical connection as to hydraulic to be legal.
    Have to give that some more thought.
  19. divorced
    Jul 20, 2004
    5,115
    A mechanical connection would be cool because it would give some hope of stopping in the event of a busted brake line. The rear calipers on newer vehicles work real well... if only I could get something on my old junk that works as well.
  20. divorced
    Jul 20, 2004
    5,115
    And I think I will call you on Monday or Tuesday to order a set of the "old" style brackets with the 8 holes... before you stop production.
