New driveshaft with 4in lift???
Discussion in 'The Garage' started by k30gambi, Nov 10, 2002.
  1. k30gambi
    k30gambi 1/2 ton status
    Dec 24, 2001
    108
    illinois
    Got the 4" rough country on, looks sweet. I've had a front driveshaft with a CV joint and it's got notches that wont let it angle down to get to the axle. The driveshaft before that, which I still have, has just a regular u-joint on the t-case end. It will flex enough but it is too short and even it is pretty close (a couple degrees) to being too much of an angle. Who makes a shaft that will work and how much extra travel should it have for susp flex???? /forums/images/graemlins/smile.gif
  2. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Grind off the stops on the front dshaft that is causing it to bind, put the frame on jackstands to let the front axle hang down, if it still binds, grind some more.
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Everyone around here recommends Jess at High Angle Driveline. He should be able to make you a front shaft that would be plenty beefy for your K30.
    While my setup is a bit different than yours, my stock front driveshaft works fine with my 4" Rough Country Lift. It came factory with a CV at one end and needed no mods. /forums/images/graemlins/burb.gif
  4. k30gambi
    Dec 24, 2001
    108
    illinois
    I thought about grinding it, just wanted confirmation from the expert. /forums/images/graemlins/grin.gif
  5. BlueBlazer
    Feb 15, 2001
    1,940
    Youre damn right Im the expert. J/K By the way, we just got a new Deere 8520 at school with the independent front suspension and " active seat". Hope youre still coming back so you can work on it. Later
