New engine please...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BranndonC, Oct 23, 2002.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i mentioned before that i can get an LS1 and i'm still thinking about it.... i found 383 Stroker but it's pric and it has a cast iron crank shaft and i heard those might break compaired to a steel one. Where as the LS1 has the steel shaft and a 6 bolt someting or other. If i can get the LS1 does anyone see any other incompabilites? i would use it with my current 700R4 and maybe get the computer set up for it.
  2. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    If you really want a stroker, check this one out, has a 3 year/unlimited mileage warranty, and its cheaper!
  3. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    but i gotta pass smog and don't know how to tell if that one will.
  4. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    no inspector can tell if it is a 307, 305, 400, 350, 400, 327, nothing.
    As far as i know, they only care about the number of cylinders and in trucks, big block or small block.
    if you keep ALL EGR equipment, it will pass. if not, you will fail.
    this is all "to the best of my knowledge" information.
  5. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    and would all that power be bad on my little 10 bolt? i was gonna get a dana 44 but some people have told me that it wasn't much beter than my 10 boly.
  6. zcarczar
    Feb 10, 2002
    2,495
    Just get a 14 bolt 6 lug Semi-Floater like me. That way you can keep your wheels. I know where you can get one too. I blew out my 10 bolt and thats what im going to replace it with.
  7. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    were and how much?
  8. dyeager535
    26,979
    Do some reading on motors and such. I really don't know much about the LS1's, but I'm betting carbing them kind of defeats the purpose.
    Cast cranks for almost everyone on this list are perfectly fine. Friend runs cast cranks in 2 and 4 bolt 350's, and he blows the motors up fairly often, but as of yet, a crank has NEVER been the cause of a failure, (bolts shearing, studs breaking, etc of course) and this is running at 6000-7000RPM's all night.
  9. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i have TBI and wouldn't that work with it? i don't know enough to know weather or not i'd have to "carb it"
  10. dyeager535
    26,979
    YOu can probably make it work with TBI, but the amount of power they get out of those motors, and the way they run, is only really possible IMO with injection, specifically sequential.
    It just doesn't make sense to me to take a really strong motor and "choke" it with something restrictive or that harms its original performance....they don't have a torque "curve" that reads like a topgraphic map of the Midwest because of old technology.
  11. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    Look into Sunset racecraft in Lubbock, TX. They make a 383 Stroker and it comes with Edelbrock MPI. Last time I checked the engine is around $4,300 w/ MP. I can look up the part numbers and whatnot if you want. The engine puts out about 375hp and 450tq. Its what I have in my '90 and I love it /forums/images/graemlins/pimp1.gif
