New engine power?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Predator, Jul 8, 2001.
  1. Predator
    Predator 1/2 ton status
    Jun 19, 2001
    130
    OKC,OK
    Hey all! Just finished rebuilt motor and am disappointed with the power. The motor is a 350, 30 over, flat tops, Comp xtreme 4X4 cam, edelbrock performer intake and carb, flowtech afterburner open headers. The truck is an 83 with 700r4 tranny shifting at 2400, 31" tires. It's faster than my g/f Cavalier but not by much. It has great throttle response in park but didn't plant me in the seat when I was seating the rings. I've broke the cam in and have about 14 miles on it. Does this sound right? Could the tranny be my problems or is this all it has.
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    What gears are you running? If you've got 3.08's like most 83's do, it's not going to tickle your pickle. It's also going to take quite a bit more time to properly break in - My crate 350 took over 1500 miles before the rings completely seated. Just give it time and fiddle with it - sounds like you have a good combo there.
    <font color=red>Cripplefight!!</font color=red>
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A> Updated finally[​IMG]
  3. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Well remeber the engine needs to break in and the rings need time to start sealing properly. What gears are in your truck? What compression ratio you running? What size cam? What cylinder heads? All this plays a key role in your performance. Like the old saying... your engine is only as powerful as it's weakest link.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <A target="_blank" HREF=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</A>
  4. Predator
    Jun 19, 2001
    130
    OKC,OK
    It prob has the 3.08's. The cam is the 447 with rebuilt stock heads. I can only tell a mild difference in this engine and the old 305!
  5. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    Like Pugsly says, your gear set could be holding you back. I went to 3.73 and what a difference. Yes, your tranny can hold you back as well. Shift overlap on 700s is awful but nothing a good shift kit woudn't cure.
    An MSD or Accel ignition woudn't hurt either.
    Shawnboy.
    If you are having too much fun it's probably illegal.
