New ford Dana 60's
Discussion in 'The Garage' started by Grizz84, Feb 20, 2007.
  1. Grizz84
    Grizz84 Registered Member
    Dec 23, 2005
    47
    NW Georgia
    Which year newer Ford dana 60's have the same spring centers as our truck's? I've found a new, still crated, Dana 60 front for a '03 F450 for $1K and im trying to find out something quick. Im already planning on converting to drivers drop.
  2. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    First problem is that is a 10 lug hub D60.
  3. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Now I see why you want the drivers side drop in the other post. :thumb:
  4. Grizz84
    Dec 23, 2005
    47
    NW Georgia
    The guy told me it was an 8 lug 60, haven't seen it yet in person. He claims thats what year and model it goes to though. About a 5 hour drive to go and take a look at it, been trying to get some pics from him.
    Saying it is an 8 lug though, how far off are the spring centers going to be? Kinda hard to get in touch with the guy while he's at home, he drives a truck OTR.
  5. Grizz84
    Dec 23, 2005
    47
    NW Georgia
    Yup, even though its a ball joint axle....can't beat a fresh 60 for 1k.
  6. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    Pretty sure the newest 450 and 550 super doody's dont have 10 lugs like the older versions, but rather a larger 8 bolt metric circle.
  7. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    either way its not going to use the same rims as ur rear chevy axle will cuz the super dudy rims are metric, plus it will have ball joints. just find a chevy or older ford hp d60
  8. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    its a bolt on adaptor.
    and dont forget its stupid duty metric bolt pattern with super crapy unitized wheel bearing units. the whole thing is yucky. :(
  9. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I don't believe the F450 brakes fit in a 16" wheel. Its still a unit-bearing axle.
    If the pumpkin offset and width work for your setup, you have a very usable housing, gears (4.88 or 5.38), and inner shafts. The outer parts can be resold. You could refit with 92-97 outers, or go to aftermarket knuckles (eg. www.solidaxle.com)
  10. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Don't they have a 36 inch spring center to center, where ours is more like 31.5-32 inches? Or is that just the pre-superduty axles (97-down)?
  11. u2slow
    May 9, 2001
    2,217
    BC Canada
    The spacing is at least 36"... if not wider.
  12. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Ryan22re is correct; the newer axles have a 36.5" spring spacing, whereas our GM's have 32.5" spacing. The ford D60 you are looking for came from 78-79, and possibly earlier models also.
    Jimbo
  13. FOR MUD
    FOR MUD 1/2 ton status Premium Member GMOTM Winner
    Apr 6, 2006
    2,801
    387
    Clayton Del
    F-450s use 19.5 rims, you are going to have problems with rim clearances. On the good side most of them run 4.88 gears. The unit bearings cost $450 ea to replace or $1600 to switch over to real bearings.
  14. Grizz84
    Dec 23, 2005
    47
    NW Georgia
    mmmkay, scratch that idea....im starting to lean more and more into just buying a complete setup from boyce.
  15. protechk5
    Sep 26, 2004
    2,015
    VA
    dont do that unless you got a ton of extra cash, you should be able to find a good chevy d60 or even 78/79 ford hd d60 ready to bolt right up with everything you need for less than $1500
  16. merace19
    merace19 1/2 ton status
    Sep 19, 2003
    372
    Mobile, Alabama
