new front drive shaft
Discussion in 'The Garage' started by supernaut, Aug 21, 2005.
  1. supernaut
    supernaut Registered Member
    May 2, 2005
    94
    Seattle, WA
    getting ready to call Jesse tomorrow for a new front driveshaft. :D he said to measure from center of u joint to center of u-joint. My old front drive shaft is long gone. I measured from center stud to center stud (the big stud that has a nut on it located at transfer case and front end) and got 30-1/2 ". from the center of the bearing cap retainer on either end i got 30-1/4".
    Sound about right?
    2" lift...
  2. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    Sounds like you measured correctly :wink1: the measurments on mine is 51 1/4 inches, imagine that! :rolleyes: yes that means under 18 inches between rear of T case and front of rear axle :doah:
