New front shock mounts?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Gold Rush, Sep 23, 2001.
  1. Gold Rush
    Gold Rush 1/2 ton status
    1,498
    Alright everyone give me your opinions. I was thinking on how to improve front travel without costing much. How about putting in a crossmember and mounting top of shocks to it so there wouldn't be a need for super long travel shocks?? Like so many have changed the mounting position in the rear, why wouldn't the same idea work in the front? The angle would be inward and the shocks wouldn't need to twist like they do now.
    Let's hear your ideas on whether this would work or not!!!
    David
    <a target="_blank" href=http://www.extremeblazer.com>http://www.extremeblazer.com</a>
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I say go for it, i don't see any difference then the rear set up's people are running. Who knows if it turns out killer we all may be needing to do some fabbing
    <font color=red>Defeat is not being knocked down, it's not getting back up</font color=red> <font color=black>Stand Strong, Stand United</font color=black>
    <font color=orange> 1955 Willy's</font color=orange>
  3. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    I think I've seen a picture of this front shock idea on the board here, If I remeber right, the dude was flexing out on a semi-truck loading ramp or something like that. Can't remmber for sure, but in the pic, it looked like he had the front shocks inboard the frame rails and tilted in at the top. Even so, I would think that there would be a clearence issue with the shocks and engine oil pan area. If the axle moved streight up, not articulated, there might be a problem. Kinda' depends on how much lift tho'. On the street, I think a sway bar would be manditory, with the shocks located inboard and tilted inboard there would be almost no reststance to body sway in a turn.
    <font color=green>1015</font color=green>
    <font color=blue>Twiztid</font color=blue>
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    You can get 13.5" travel Doetsch shocks for less than $40 each - Probably far less than it would cost (atleast headache wise) to relocate the mounts to a cantilever-type setup.
    Special thanks to those lost from IAFF Locals 94 and 854 - You shall never be forgotten
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  5. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    $40 bucks !? Now ya tell me!
    I like the shocks mounted out-side the frame rails, this way it would help with body sway and make it more preditable. The Ford shock tower thing seams to be a easy way to go to get the upper shock mount located higher to clear the longer front shocks. Just my opinion.
    <font color=green>1017</font color=green>
    <font color=red>Twiztid</font color=red>
  6. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    $26.69 for the DT-3000 hydraulic, or $34.39 for the Prerunner cellular gas from Summit Racing.
  7. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    What'da ya doin'? Rubbin' it in? -jerk! [​IMG]
    <font color=green>1020</font color=green>
    Twiztid
  8. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
  9. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Don't I just suck?!?[​IMG]
