New Fuel System
Discussion in 'The Garage' started by AntAZBlaz, Jan 17, 2005.
  1. AntAZBlaz
    AntAZBlaz 1/2 ton status
    273
    Mesa AZ
    Hey everyone it’s been a while but I have a question,
    I have a 383 with an Edelbrock 1906 carb and I want to replace my fuel pump and fuel lines from the pump up to the carb and place an in line filter instead of the one that is mounted in the carb.
    I have run into a lot of issues with not being able to see what’s going with my filter which I believe is the reason my truck keeps on having a surging problem.
    I was looking for an upgrade as well if necessary because the fuel pump currently I’m using the one from my 350 and I’m not sure if it is putting out what the 383 would like.
    I was looking to buy a systems that uses the nice braided steel lines out of the summit catalog but I’m not really sure of what parts/kit is best for what I’m looking for any one have any suggestions?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Surging could also be a vacuum leak near the carb or associated hoses etc . Now as for a pump for a carb , if I had the money I would run something like this Clicky
    As for hoses and line , I would do a metal hose following the factory bends closely up behind the alternator , with just a short section of hose connecting the fliter to the carb and fuel line.
    I could of very easily said get an electric pump , but by staying mechanical you can always use your old 13.99 A-zone oump as a trail spare so you get home :k5: :k5:
  3. AntAZBlaz
    273
    Mesa AZ
    thanks do you know of any hose kits that are ready for the application? ie connections hose fuel filter? and i'll check the vacumm too
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I'd have to look , but I am sure Jegs has something , or you can use the stock one :k5: :k5:
