New gauges w/ pics
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by outsider223, Jun 29, 2003.
  1. outsider223
    outsider223 1/2 ton status
    Mar 17, 2002
    122
    Green Bay, WI
    Just finished installing new gauges to replace the original idiot lights. Gauges are so much better, now I can actually tell whats going on under the hood.
    Gauges
    Installed Gauges
    Wiring
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Right on, looks good....what did you do with the cluster housing in getting them to fit? I've been wanting to upgrade my gauges.
  3. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    nice /forums/images/graemlins/thumb.gif
  4. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    very nice... /forums/images/graemlins/thumb.gif
    I need to do mine just because half of them don't work anymore...
  5. 77Jimmy
    77Jimmy 1/2 ton status
    Sep 3, 2002
    661
    Atlanta, GA
    Very nice!!! /forums/images/graemlins/thumb.gif
  6. outsider223
    Mar 17, 2002
    122
    Green Bay, WI
    To make room for the gauges, I cut out the back of the cluster housing with a dremel tool. I left the "ring" if you will where the dash screws into the cluster. I left the printed circuit intact because some of the original lights use a ground on that.
  7. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Kewl. What size gauges did you use to fit the ring 2 1/16"?
  8. BayouBlazer88
    BayouBlazer88 1/2 ton status
    Jul 31, 2002
    353
    Lafayette, LA
    What aftermarket gauges did you use? and what did you put in place of the stock fuel gauge? and it looks great if I might add.
  9. AntAZBlaz
    AntAZBlaz 1/2 ton status
    273
    Mesa AZ
    great job i wish i had that look.
  10. outsider223
    Mar 17, 2002
    122
    Green Bay, WI
    Bayou - I used Autometer's Phantom gauges. I think they are listed under racing gauges. They are the electrical short sweep version. Right now the stock fuel gauge is still sitting there with nothing hooked up to it, by the end of the summer I plan to put a tachometer in that spot. It wasn't that hard of a job, it just took some time to make it look good.
    Diesel - They are the 2 1/16 diameter gauges.
