new gear box now it squealing ...ahhhhhhahhhh
Discussion in 'The Garage' started by limey, Feb 26, 2004.
  1. limey
    limey 1/2 ton status
    Dec 17, 2002
    121
    midland texal
    Just bought a new power steering gear for my 74 gmc and now when I lock the wheel all the way to the right or the left it squeals. Do I need to take the new gear back off and switch it for another one. Or some one told me it could be my old pump. Any one have any ideas.
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Air in the system. Need to rebleed it.
  3. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    belt tight enough?
  4. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    Sounds like you need to tighten or replace the belt. That's not an uncommon problem, I've always been able to tighten the belt a little and it goes away.
  5. limey
    Dec 17, 2002
    121
    midland texal
    i will try to tighten the belt and see if that works. but as for bleading it i put fluid in while jacked up and turned it back and forwards about 20 times and the started the truck and turned it. is their any other way to bleed the system. thanks
