New Gear Q
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lifethroughdeath, Aug 14, 2003.
  1. lifethroughdeath
    lifethroughdeath 1/2 ton status
    Jan 26, 2003
    300
    New Bedford, MA
    when i get new gears for my truck do i need to install a new carrier as well or will the original stock one work? i've only got corporate 10 bolts now with stock gearing i belive,, but i've recently jumped from stock 235/75/15's to a 4" lift and a set of 35/14/15 Ground Hawgs, i havent decided on gearing yet but i can get a good deal on a set of 4.56 richmonds what do you think? /forums/images/graemlins/k5.gif /forums/images/graemlins/angryfire.gif
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    That depends on your current gears. There are 'breaks' on the carriers as far as what gears will work, some research is required.
    Usually the cheapest, and easiest route is to find a set of 3/4 ton axles with the gear combo you want. (Be sure to add in the cost of new rims though.) This not only gets you better gears, but increases your strength as well....
    Unless that is a 'thick' gear, I believe you need a new carrier....
