New gear setup... Is it okay for backlash to be .002" too wide?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fad2blk99, Sep 30, 2003.
  1. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    New gear setup... Is it okay for backlash to be .002\" too wide?
    I am fighting with the setup on my 10 bolt front...
    I'm installing new 5.13 gears and an Eaton posi. The Yukon gear install manual says backlash should be between .006 and .010". My current backlash is just just under .012"; However, my pattern looks pretty good... it does have somewhat of a flat line at the flank (root), indicating the pinion may be a little "close"
    Sorry, No pics... my digital went swiming last week. /forums/images/graemlins/mad.gif
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    Re: New gear setup... I it okay for backlash to be .002\" too wide?
    i would suggest getting it down to about .008" only because once you actually drive it, it will loosen a tiny bit to maybe .009"
  3. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    If I had only taken the carrier out a couple of times up to now... /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
    Without exagerating, I've pried the carrier out 9 times. In doing that, I've cracked a shim /forums/images/graemlins/angryfire.gif burred the piss out of the machined edge where the shims seat against the housing /forums/images/graemlins/angryfire.gif and trashed a set of races /forums/images/graemlins/angryfire.gif. I'm hoping I can be okay at .012", although, like you said, I'd prefer to be at .008 or .009".
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Re: New gear setup... Is it okay for backlash to be .002\" too wide?
    I'd take it out again and make it right, pulling it out now will be a hell of a lot easier than doing it later after the bearings are trashed. /forums/images/graemlins/deal.gif
  5. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    why "cant" you get it any closer? It needts to be within that spec or like confed said over time with wear it will just open up more then you get that super CLUNK in the gears. I know it sucks I just did mine a few months ago didn't think I was ever gonna get it right. Good Luck
  6. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    Yeah, I was pretty frustrated last night... Now that I've had a chance to sleep on it, I'm gonna tear back into it. Thanks for helping me see the light... /forums/images/graemlins/thumb.gif
