new GM crate motor and a 1st gen.....some questions
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by jakeslim, Jul 4, 2004.
  1. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    I will be looking to drop a GM crate into my 69 k5. What should i be aware of related to mounts, oilpan etc. Is it a direct drop in? Also, I have a 4 speed manual..anything needed to put in a new crate?
    lots of question in the next few weeks!
    thanks,
    Paul
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    make sure you put in the pilot bearing, also make sure the crate enigne is compatible with your flywheel. the engine crankshaft changed in 86 from a two piece rear seal to a one piece.
    everything else should bolt right in, unless you are getting a vortec engine. then you would need a new intake manifold.
    ARQ.
  3. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    thanks. Won't be getting a vortec. Just a base crate with no frills. I wonder if I can get something with no intake, no carb, no starter, no distributor, etc. That way I can modify just a bit.
    /forums/images/graemlins/waytogo.gif
  4. stretch67
    stretch67 1/2 ton status
    Nov 1, 2003
    171
    bozeman mt
    most of the gm crate motors come minus dist carb etc. so you can buy the parts you want instead fo buying them twice! /forums/images/graemlins/yikes.gif
