New GM NV4500 & LH Drop TC on eBay
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by JungleBoy, Mar 27, 2002.
  1. JungleBoy
    JungleBoy 1/2 ton status
    Jan 31, 2001
    243
    Houston TX
    He makes it sound like a piece of cake to move the differential from RS to LS. Maybe it is...
    <a target="_blank" href=http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&amp;item=1815913253>http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&amp;item=1815913253</a>
  2. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    I think he's full of garbage on converting the front axle for a LH transfer case. The D44 and D60 differential housings have a spring pad integral to them for the right front spring. There's no pad on the opposing side of the housing, so where in heck is the left spring supposed to sit after the axle tubes are swapped?
  3. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    Sounds too complicated to me. I agree with Steve, Where would you put ths spring perch unless you could weld one on the outside on the diff casting.
    Will
  4. JungleBoy
    Jan 31, 2001
    243
    Houston TX
    I agree - I thought his explanation was fishy. I think the TC is of such narrow application as to be nearly worhtless - a guy might pick up the trans reasonably, who knows. Although I saw a 67 Corvette owners manual "first edition, mint" go for $178 and I saw some guy on the Corvette Forum "said" that some nut paid $2550 for "NOS" early Camaro door sill plates which are still available from GM for under a hundred bucks...
    Note to all - before buying "NOS" on ebay, please check your GM parts guy... Pretty common for me to buy new GM stuff for less than LMC or the like.
