new guy w/ question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sapper, Jul 13, 2001.
  1. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    with the 14 bolt what is the difference in ff and sf? and in a truck only going to 38s would there be a big advantange to either one?
  2. nd_4_mud
    nd_4_mud Registered Member
    Mar 16, 2001
    40
    new jersey
    Welcome to the board. The difference between the ff and the sf is that the ff's axles are bolted to the rear and the ring diamiter is 10.5 inch. And the sf is a c-clip that holds the axle in the houseing and the ring diamiter is 9.5 inch. With 38 i would run with the ff and not the sf. If i am mistaken please let me know.
    Knowledge is the key to the universe, and I hold that key when i am sleeping.[​IMG]
  3. sapper
    Jul 11, 2001
    3,052
    NoVa
    hey thanks, i'v read enogh to know that the ff is stronger just not sure if there was a certain tire size or horse power limit for the sf. probably go with the ff in the end. thanks
  4. Grim-Reaper
    7,385
    Atlanta
    Once you get up in the size range your past the gray area with a 12 bolt your way past it with a 10 bolt and if your going to wheel it leave the front open and still expect breakage. Really your into the D60 front area of the game or you better get use to replacing axle shafts. 36's is pushing it with the D44/10 fronts and 12 bolt rear.
    It's not my damn planet monkey boy!
    <A target="_blank" HREF=http://communities.msn.com/OffroadK5s>http://communities.msn.com/OffroadK5s</A>
    Grim-Reaper
  5. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    You can break an axle on the FF and the wheel/axle stays with the hub as opposed to your wheel falling off and causing even more problems with the SF,12, and 10.
    Dave
    If You Drink Don't Park, Accidents Cause People.
  6. sapper
    Jul 11, 2001
    3,052
    NoVa
    well that makes it an easy choice. you will know when i find one- more questions
