new here 92 tbi 350 to carb conversion
Discussion in 'The Garage' started by 77scottsdale, Dec 21, 2006.
  1. 77scottsdale
    77scottsdale Registered Member
    Dec 17, 2006
    93
    georgia
    i iam putting a 92 350 in my 77 k10 4x4 short bed , will it be a good engine for a 4wd being that it has the swirlport heads, planing on headers, performer intake, 600 double pumper holley, and a summit cam 262/272duration, .420 .442 lift. plan on running this engine till i get my fourbolt motor where i wont it (383)
  2. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    I put a 92 350 in my 78 K5. I used a performer intake and had to modify the 4 center bolt holes to compensate for the different angle of the bolt holes on the TBI heads. I also had to go with an electric fuel pump since a 92 wont accept a mechanical fuel pump. I think the pump cost like $26 at napa. The power is decent for what it is.
  3. sweetk30
    Nov 1, 2004
    25,538
    538
    horseheads , ny 14845
    i wouldnt run that holley in a offroad truck at all.
  4. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    you can but the manifold with the correct center holes so you don't have to modify, i just got rid of one, but i've seen em on ebay for about 80 bucks
  5. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Run a Q-Jet or off road Holley, the 600 DP will stall the engine off-road at angles and just hitting bumps. Ive seen 'em stall while just going down rough dirt roads. Best would be to keep and run the TBI set-up. It can be easilly modded to make and handle more power and would be better than carb off-road, for fuel mileage, and throttle response.
  6. 77scottsdale
    Dec 17, 2006
    93
    georgia
    reason iam running the carb is because i dont wont to spend any money on a new one my dad bought this 600dp in 05 and its almost new, and its free to me. i hope it will de fine for a couple of mud runs and a few trails along the way, not going to go on any hard step trails till i get it lifted up some
    what psi electric fuel pump do i need for a carb, i saw a 4 to 6 psi carter at summit for 65.95
  7. 77scottsdale
    Dec 17, 2006
    93
    georgia
    also i just bought some off-road needle and seats that are spring loaded,
  8. BizeeB65
    BizeeB65 1/2 ton status
    Oct 12, 2005
    859
    Louisville, KY
    you will be sorry you ditched the TBI once you get in an off-camber situation and your carb floods the engine. Spring loaded needles and seats help.... a little. I am going the opposite way you are... I have a 600cfm edelbrock with spring loaded needles and seats, and I still cant do hillclimbs without stalling. So I picked up a complete TBI system that is getting swapped in.
    Good luck with the carb thought. If you can get access to a q-jet, you may have better luck, as I hear they run on thier sides! :eek1:
  9. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    The carter electric pump will be ok for your mild mill. And make sure you have the right intake for the TBI heads.
  10. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    ok im lost, some one tell me what TBI is? im not a chevy guy by trade
  11. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Throttle Body Injection
  12. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Throttle Body Injection. On these models it looked similar to a carb but was a 2 barrell unit with 2 computer controlled injectors. Better cold starts, mileage and throttle response, and better off road. I think it was 200 HP at 4000 RPM and 310 pounds torque at 2400 RPM. With a few mods, headers n exhaust and a chip and you could probly get 250 HP. My next rig will be a TBI Blazer.
  13. Mr.Jimmy
    Mr.Jimmy Registered Member
    Nov 20, 2006
    66
    Albuquerque, NM
    I bought an 88 burb just for the tbi stuff. ripping off carb stuff. let me konw if you want any of this crap.
  14. 77scottsdale
    Dec 17, 2006
    93
    georgia
    how many post do i need to look at attachments
  15. Mr.Jimmy
    Nov 20, 2006
    66
    Albuquerque, NM
    pretty sure you need to purchase a membership
  16. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Holley mods
    Success varies for everyone a bit. I run a holley 780 vacum secondary with no problems on large hillclimbs or side angles. It has center hung fuel bowls that I've retrofit with whistle baffles front/rear, spring loaded needles and and extended vents. No issues so far.
  17. Mr.Jimmy
    Nov 20, 2006
    66
    Albuquerque, NM
    no carb will give you crisp throttle response, let you run at the leanest possible air/ fuel mixture, and forget a steep hill, fuel injection will run upside down! my truck runs rich as hell and without re-jetting it, it blows black smoke. soon as i get a computer chip, im slappin on tbi.
  18. 77scottsdale
    Dec 17, 2006
    93
    georgia
    tbi is not really that much better than a carb you will spend around 250 300 for a chip plus what ever you have to pay for a good tbi setup, plus new injectors, ill stick with the carb
  19. 77scottsdale
    Dec 17, 2006
    93
    georgia
    if your going to go fuel injection go with a holley kit, or edelbrock mpi
  20. 77scottsdale
    Dec 17, 2006
    93
    georgia
    here is a link to some pics here
    any one know of any good k10 fourms
