New hubs
Discussion in 'The Garage' started by burban1500, Mar 16, 2006.
  1. burban1500
    burban1500 Registered Member
    Nov 27, 2003
    46
    Lavallette, NJ
    Hey all, I just got my warn standards installed today and noticed that their is a slight bit of play if i grab the hub and wiggle it up and down. Its just a slight movement but i was curious if anyone else has the same thing and if this is normal. Im pretty sure their in right, i removed the c-clips and washers also.
    Thanks-
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    did you install the outer rubber gasket?
  3. burban1500
    Nov 27, 2003
    46
    Lavallette, NJ
    yes-if its the o-ring that goes on the dial part of the hub.they were pretty cheesy and small looking. The hub moves more so in and out slightly as opposed to up and down.
  4. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    Not normal, no play should exist. R n R but make sure the outer snap ring (wheel hub) is in there and the inner external snap ring (for the stubshaft) is in there also. good luck
  5. burban1500
    Nov 27, 2003
    46
    Lavallette, NJ
    yes the outer one(the one thats a b***H to take out) is in and so is the the snap ring that goes on at the end of the stub shaft. Im stumped, Im not supposed to use the old seal from the automatics am I?
  6. onetonbb74
    Dec 1, 2005
    2,083
    Campbell, CA
    Have you tried the other side yet. The hub could be bad on that one side (but i doubt it) . If everything is installed correctly and it still has the play, i would rtv the outer edge of the dial part where the o-ring is and then wait for it to almost dry (tacky) then install. Even with a little play it shouldnt break because of the play. Id run it. BTW if the old seal from the auto's makes a tighter fit id reuse it.
  7. rlhenry
    rlhenry Registered Member
    Mar 6, 2002
    93
    Morenci, AZ
    Believe it or not, some axle stubs have the groove for the snap ring in different locations. I had to cut a new groove in both of the stubs on my '84 to make things fit snug. My Dad's '88 Sub had two sets of grooves; one that worked for the auto hubs and the other worked for the Warn's. The location on my K5 created play on the backside of the knuckle because the flange wouldn't seat against the inner spindle seal. I didn't assemble the hub any further from that point so I don't know if it would also cause play in the hub itself, but it might be worth looking at.
  8. burban1500
    Nov 27, 2003
    46
    Lavallette, NJ
    Both sides have the same amount of play. Im just gunna rtv them and run em. They seem to be working fine so well see what happens. Thanks for the replys.
  9. nemesis_pyros
    nemesis_pyros 1/2 ton status
    Mar 24, 2004
    229
    Winnipeg, Manitoba
    This is normal to me. Both my truck and my dads truck have a little of play when you grab the hub and wiggle it. I've never had a problem related to that little bit of play. I would just run it, rtv it if you think it'll see a lot of water but when I put mine in I didn't bother with the RTV. It wouldn't matter for me cause the seal and that needle bearing on the backside of the knuckle are both shot.
