New K3500 Dually Crew Cab, what T Case and Rear?
Discussion in 'The Garage' started by bigblock454, Sep 10, 2003.
  1. bigblock454
    bigblock454 Clack Clack Clack Premium Member
    Jun 18, 2002
    546
    16
    Terre Haute IN
    I just bought a new K3500 Dually Crew Cab 454. I thought it would have a 14FF but it doesn't, is it a Dana 80, does it have a NP205(it is cast iron)?
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Clean the housing around the center section, particularly around the pass. side lower. Look for a 70 or 80, I think it will be a 70.
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> If it's the 88 listed in your sig, it should have the Dana 70 and I beleive a 205. If it's a NEW new one then it will have the 11.5" 14 bolt and probably some high-zoot transfer case with lots of bells and whistles that would cost a bajillion dollars to replace. </font>
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    What year is this truck?
  5. bigblock454
    Jun 18, 2002
    546
    16
    Terre Haute IN
    Sorry guys, it is a 1988. The one in my sig.
  6. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    If it's a pick up (not a cab&amp;chassis) then the rear axle will definitely be a D70HD. If the case is iron then it's a 205, no doubt. /forums/images/graemlins/thumb.gif
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Ok, if its a crew dually, it will be a V30, not K, and the rear will be a D70 as these are standard dually rears for the fleetsides whereas the cab-&amp;-chassis models will have the narrower 14FF dually rear.
    Just think of it this way: any GM 1 ton dually that came with a regular bed (with the wider fenders) will almost ALWAYS have a D70 and those with no beds or if they have utility beds, flat beds, etc, they will likely have the 14FF.
  8. dyeager535
    26,977
    So with all that said, what dictated which t-case the truck got?
    The '91 I pulled my transfercase from was obviously a 205, but I believe 241's were also installed in one tons that late?
    Engine size?
  9. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    Based on the fact that I've never seen otherwise, I believe all *crew cabs* came with 205's. I know the reg cab trucks (81-87) can have either 205 or 208 but I've never seen a crew cab with anything else (except, of course, the pre-80 full time trucks with a 203).
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    All the V-series 1 tons got the 205 t-case, like the K-series.
    This '88 V30 will have a 205 also. Since its a crew cab, the rear output on the 205 will be a fixed yoke. Regular cab 1 tons have slip yokes.
    241's, and 208's, were available standard on the K and V-series in the 10's and 20's but only the 208 was available for the 1 ton in the M-series trucks.
  11. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I have a friend with a 95 crew cab dually( not the cab&amp;chassi) and it has a 14boltFF instead of the D70. Is this odd?
    85K5 3/4ton,14boltFF,10bolt,9"lift,35"boggers,16.5x14welds, big horse 406SBC/700R-4 /forums/images/graemlins/k5.gif /forums/images/graemlins/angryfire.gif
  12. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> It's not odd on the later body style trucks. </font>
  13. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Oh, thats what I figured
  14. bigblock454
    Jun 18, 2002
    546
    16
    Terre Haute IN
    Yep, I found HD70 cast into the rear last night. How does this compare to a 14FF in strength?
    It is a Crew Cab 3+3.
  15. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    Both axles have 10.5" ring gears and 1.5" axles. The D70HD housing is stronger due to the larger axle tubes and more webbing on the center section, the carrier and inner pinion bearings are considerably larger than the 14 bolt counterparts.
    Realistically, either axle will do anything the truck itself is capable of but ultimately I'd have to give the Dana the win.
  16. bigblock454
    Jun 18, 2002
    546
    16
    Terre Haute IN
    How about the outer hub bearings? Is the Dana larger?
  17. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    No, the wheel bearings are the same as a 14 bolt. In fact, U2Slow pointed out that dually 14 bolt hubs will interchange with the D70HD.
  18. thatK30guy
    Jan 12, 2001
    32,076
    55
    Actually, I've found out thru various info that the D70's ring gear is 10.54" which gives it that .04" advantage over the 14FF. /forums/images/graemlins/thumb.gif
