New K5 Owner - Could use some information, etc.
Discussion in 'The Garage' started by Blazer Jim, Feb 14, 2006.
  1. Blazer Jim
    Blazer Jim Newbie
    Feb 14, 2006
    3
    Austin, TX
    Fellow K5'ers, I recently purchased a 1991 project Blazer. Great bones and muscle, but a few dings, dents, and scrapes on her. I have a couple of questions that I hope you all can assist me in.
    1) Carfax report states 1991 Chevy Blazer V10 - What's the V10 signify? I do know that there's not one under the hood.
    2) Rear shocks are loose (can't tighten) - I'd like to replace the hardware. Any information on the size would be helpful - spacers, washers, bolt, retainers, etc.
    3) Oil leak from the oil cooler lines - common problem?
    4) Hard shift in 1st gear? Possible problem or common in K5 tranny?
    5) Any site that can give me information based on VIN number?
    6) As a "registered user" can I only post in the Garage and not in the "Technical Forums"?
    7) Any good sources for interior parts, etc.?
    8) My goal is to get her back to stock - ultimately showroom!
    Thanks. It's great to be an owner.
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    V10 is a designation, like K5 or S10.
    Sheock loose, define loose, and why cant you tighten them?
    Harsh shift, check tranny fluid level/condition.
    Parts, Here or LMC
  3. Blazer Jim
    Blazer Jim Newbie
    Feb 14, 2006
    3
    Austin, TX
    Leper, the shock nut on both sides tighten to about 1/4 inch short of flush on the frame. Looks like a spacer or a couple of washers are missing. Previous owner replaced the shocks and apparently didn't do it right.
  4. Blazer Jim
    Blazer Jim Newbie
    Feb 14, 2006
    3
    Austin, TX
  5. freeflow
    freeflow 1/2 ton status
    Nov 6, 2004
    274
    alexandria, minnesota
    lmctruck.com they will send u a free catalog- good company
    brad
  6. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    LMC :waytogo: . I would first change fluid and filter n tranny. Some autoparts stores carry hardware kits for the shocks. Search Google or Yahoo theres quite a few sights out there that will help with VIN decoding, engine/traanny/t-case/axle identification and all kinds of other tid-bits of info. Also I would suggest coughing up the small amount to be come a member here. Allows you to do more and obtain more info as well as keep this great sight running and improving. And with the truck being 15 years old I wouldnt be surprised if there is a leak or two. Shouldnt be too hard to fix.
