New lift + Dana 60 = driveshaft question
Discussion in 'The Garage' started by sandawgk5, Jan 21, 2006.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Hola,
    As some of you know I have been installing a 4 inch lift and 1 tons this weekend as well as a few odds and ends. Well Roz and I got the lift in the the Front 60 in and the front is on the ground. Now the question I have (cause I am a dumbass and did not measure the old before I removed it) is this on my front driveshaft I only have about 1" of compression at ride height with all weight on the front axle. Is this enough? or do I need to have an inch taken out.
    Ira
  2. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    When I swapped in my 60 I had to shorten the front shaft(about 1-2'' I think). You wont want to risk shoving the shaft back through the t-case when you flex out!
  3. sandawgk5
    Oct 28, 2003
    6,881
    I know a lot of guys have done this and said no driveshaft changes were necesarry help me out. I just need to know how much slip is left on most peoples shafts (for compression) and I mean Driveshaft :D
    Ira
  4. sandawgk5
    Oct 28, 2003
    6,881
    If I do have to get my front Driveshaft cut down how much do I need to have cut off? How much room should I have for compression of the springs. I have a 4" spring in front nothing special.
    Ira
  5. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    You can look at mine tomorrow. I cleared it with the wifey
  6. sandawgk5
    Oct 28, 2003
    6,881
    kewl so did I:D. You have 6" but Driveshaft slip should be close to the same correct?
    Ira
  7. readymix
    May 30, 2004
    6,706
    26
    If you want we can put my shaft in your truck just to check the length. Should only take a few minutes.
    What tools should I bring....then again, I will probably just bring my trail assortment so we don't have to wait to share tools.
    I plan on leaving Temecula around 1200. That will give me time to get new ATF and all that crap I will need to fix my 208. If I don't get to it at your place then at least I have the materials for later.
    Any favorite beer?? I will PM you my cell number so you can call me when you get home from work
  8. sandawgk5
    Oct 28, 2003
    6,881
    Beer of choice would be cold:D. Roz has a pretty good assortment of tools and his driveway is big enough for 4 full size rigs with room to work on all of them:D. I gotta get Tranny and brake fluid as well as powersteering and the 2 bolts for the Dana 60:doah:.
    Ira
  9. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i have 9" with axle moved forward 1.5" and the stock shaft is long enough. the pinion is about 2" longer than a 10b, which worked out perfectly for me :-)
  10. sandawgk5
    Oct 28, 2003
    6,881
    My problem is I think with only 4"lift and adding a Dana60 my front shaft is too long.:o
    Ira
  11. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I didnt have to cut down my DL when I did a 60 swap and 4in lift. Bolted right up and went wheelin with no problems.
  12. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    get zero-rates and move it out 1.5", then you'll be good for sure :D
