New Lift...help!!!
Discussion in 'The Garage' started by SUB-ZERO, Mar 17, 2005.
  1. SUB-ZERO
    SUB-ZERO 1/2 ton status
    Oct 8, 2002
    219
    Virginia Beach,Va.
    I have a 87 Jimmy. Just finished installing a new 4" Rough Country lift.I did not use the sway bar drop brackets 'cause it bolted to the frame without them.I also eliminated the dual shock setup and just went with one(on the rear of the front).I did use the raised steering arm and longer brake lines.Did not shim the axles or drop the transfer case.Heres my problem...on the way to the tire shop to get new 35" tires it started to wobble violently.I suppose this is what is described as the "DEATH WOBBLE"? I did a search and read all the posts associated with this but none address getting this right after a new lift and before larger tires.It did not do this before.Any thoughts?
  2. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    where you at in VA? death wooble is more for the dana60. Did you check your ball joints? Is your drag link tight?
  3. doggystyle
    doggystyle Registered Member
    Jan 31, 2005
    8
    washington
    are you sure your ubolts are tight? i have had and seen alot of dana 44s with some pretty violent wobble.
  4. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I experienced something similar. It turned out one of the drag link ends (the one attached to the steering arm) was loose.
    John
  5. SUB-ZERO
    Oct 8, 2002
    219
    Virginia Beach,Va.
    I am in the Lynnhaven area where are you at.I torqued the u-bolts to 90psi.Is that adequate?It might be the drag link 'cause it looks pretty tattered.Its tight though 'cause I had to remove it to install the raised steering bracket and again to adjust the steering wheel.I will check it again though.
  6. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    You need 130 foot pounds of torque.
  7. JIMs70K25
    Dec 31, 2001
    524
    Chesapeake, VA
    Deep Creek
  8. ZooMad75
    ZooMad75 1/2 ton status Premium Member GMOTM Winner
    Apr 5, 2003
    1,007
    609
    Pueblo, CO
    I just went throught the same lift this last weekend. Did not use any drop brackets for the sway bar since the rough country kit did not come with any. I did use the raised steering arm. NO Wobbles with the front end torqued together. Something must be loose or do you have a steering stabilizer?
  9. SUB-ZERO
    Oct 8, 2002
    219
    Virginia Beach,Va.
    You ain't that far..about 30 min.We should get together sometime.The Jimmy is my buddies.I have a 85 K5.I just got mine back from having the whole truck Line-x'd inside and out in Viper Red!!!You should see it!It looks bad a$$!Gonna start building some bumpers this weekend.
  10. 85scottsdale
    85scottsdale 1/2 ton status
    Dec 22, 2003
    283
    Lewisville, NC
    I had a all spring 4" Rough COuntry kit on my truck and had no issues, make sure everything is tight and your ball joints aren't worn out like already stated.
  11. SUB-ZERO
    Oct 8, 2002
    219
    Virginia Beach,Va.
    Just an update...put a replacement stock stabilizer in last nite and seems to have fixed the problem.On the old cylinder the rod practically fell out!!I'd say it was toast!
  12. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Hampton/Newport News area here.
  13. SUB-ZERO
    Oct 8, 2002
    219
    Virginia Beach,Va.
    And I thought I was the only one with a REAL truck around here! What kind of truck you got?
  14. AkMudr
    Dec 30, 2004
    917
    Alaska
    Just my lil red wagon :D 85 3/4 ton, 4" on 35's 350/350/205 Xover Hysteer 14bff locked.
  15. SUB-ZERO
    Oct 8, 2002
    219
    Virginia Beach,Va.
