new lift...vibration
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazeitup, Jan 9, 2001.
  1. blazeitup
    blazeitup Registered Member
    Oct 15, 2000
    6
    Longmont, CO
    I just put a new 6" Skyjacker lift and 35" BFG Muds on my '86 K5 a week ago. I have a vibration from about 15 to 25 mph. I have allready moved the t-case spacers. I think it might be the forward u-joint on my rear driveshaft. I replaced it about 2 months ago so it is realatively new, but maybe the angle is too steep. I also put a 14 bolt FF in the rear and used the offset u-joint there. So I was wondering if anyone has any ideas about that. I also saw a post a few months ago about a 700r4 speedo calibration kit...any info about it would be great. thanks
  2. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    The first thing you should do is check your angles and make sure the are equal but at oppisite angles. You can get a dial angle finder at Harbour Freight or Sears. I installed a similar setup in my K5. My angles were at 17-19 degress and a little to steep for my taste. So I installed this and moved the axle pinion up to nearly eliminate that angle.
    <IMG SRC="http://albums.photopoint.com/j/View?u=1439605&a=10797147&p=37537438&Sequence=0[/image]
    [image]http://www.metro-dade.com/firerescue/images/web elements & logos/testpulse.gif">
  3. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    tHAT IS THE C/V SET UP YOU NEED THERE-
  4. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Driveline man!! The CV shaft that is in the above pic, can it be used with a solid shaft and a slip yoke?
    Will work for parts, beer and sex.
    90 Jimi,350/700R4/241/10bolts/3.73's/33's/4"
    <A target="_blank" HREF=http://mccordhouse.freeservers.com>http://mccordhouse.freeservers.com</A>
  5. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Sounds like what happened to me exactly. I have an '87, went from a 4" to 6" lift and also installed a 14 bolt FF at the same time. Mine was vibrating at any speed when letting off the gas...I dropped the t-case and it seemed to help a lot, still have a slight vibration at higher speeds (65+), but the lower speed vibes are pretty much gone. I used the ORD shackle flip and the 2.5" lift springs in rear, and my springs had shims to correct angle. Seemed like the combo was too much, but when the t-case came down it helped. I am gonna do the CV shaft when money allows, that is the only surefire way to cure it if it is still vibrating...and I don't like the t-case dropped, screws other stuff up...
