new member 90 blazer wont start
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigblazinfd, Jul 5, 2006.
  1. bigblazinfd
    bigblazinfd Registered Member
    Jun 28, 2006
    10
    kansas city, mo
    Ok so I recently purchased a 90 k5 blazer. My problem is that it will not turn over. I left the ignition on the other day for about 24 hrs before I realized it so the battery was obviously drained. I charged the battery but am getting nothing but a click and not a starter click more just a click from the ignition being turned. The battery is charged now but I am getting no lights inside or out to turn on the guages are pegged to the right. What should I do or check? I am new and trying to learn as I go here so please be patient with my stupidity here.
  2. grtwhite
    grtwhite 1/2 ton status
    Aug 3, 2000
    366
    Macungie, PA
    Welcome aboard! I know you mentioned you charged the battery, did you check to see if the battery was holding the charge?
  3. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I have to agree, sounds like a fried battery. Check your connections at the battery first though. If that does not work try a jump start.
  4. bigblazinfd
    Jun 28, 2006
    10
    kansas city, mo
    I will check to see if it is holding a charge. I tried to get it jumped and that did nothing disconnected the battery already and hooked it back up so I know the connections are good. Im gonna go play with it some more.........
  5. grtwhite
    Aug 3, 2000
    366
    Macungie, PA
    Have you checked your battery cable ends to make sure they are clean & free of corrosion? Have you checked to make sure you have a good ground connection? If you don't have a battery tester you can take your battery to an auto parts store & have them check it. They'll let you know if it's toast & gladly sell you a new one.
  6. bigblazinfd
    Jun 28, 2006
    10
    kansas city, mo
    Well I took the battery to the parts store to have them check it and it was fine so I went back home hooked it back up and it fired right up. Dont really know at this point if it was the connection or the battery but it is fine now. Checked the alternator after it started and they said it is fine to so whatever it was it is better now. Thanks to everyone for the help, I am new to this 4x4 life.
  7. dyeager535
    26,982
    191
    Just keep an eye on that battery.
    I had one that "tested" good at the parts store (I don't trust any of their tests BTW, I was trying to get it warranteed) but wouldn't crank the engine over from full charge for more than about 3 seconds.
    Could have been cables as well, but if the battery was drained like you say, it was probably pretty badly harmed.
  8. CK5
    May 19, 1999
    21,627
    704
    CO
    Also check your ignition modual.
  9. bigblazinfd
    Jun 28, 2006
    10
    kansas city, mo
    ok thanks to everyone once again this sight is really informative. I will keep my eyes on it but it is doing good so far.
  10. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    The best way to check the condition of a battery is to use a hydrometer to check the specific gravity of its electrolyte. This tests the weight of the electrolyte and condition of the chemicals in it. After time the chemicals are used up, preventing the battery from charging fully (or even holding a charge).
    The parts store probably used a load test, which will test the battery's short-term recovery ability. Its not as accurate, but if the battery responds well, it should be OK.
