New Member Needs Help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by smilee, Jan 2, 2002.
  1. smilee
    smilee Newbie
    Jan 2, 2002
    4
    Eastern Washington
    Hi, I just purchased an 89 K 5 about 1 month ago. I am having a problem with it cutting out once it has warmed up and is doing about 50mph. Thus far I have replaced the EGR, O2 sensor, fuel filter, and TPS. I have scanned it and it comes up with no codes. Any help would be appreciated, I'm running out of ideas.
    Thanks,
    Lacie
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    What about the fuel pump itself? does it do it in overdrive as well as in 3rd?
    Welcome to the site too!!!!
    If you find a way out let me know[​IMG] I'm stuck here 24/7/365*
    * not really but close enough
    <font color=red>Life is like a mud hole:</font color=red><font color=blue>
    When the S#!T gets deep, you have to keep moving and friends can always pull you out</font color=blue>
    55 Willy's
  3. Ryan B.
    Jul 18, 2001
    5,693
    CA
    I second that. Sounds like maybe a fuel starvation problem at high speeds.
    1st post too! [​IMG] Welcome to CK5 Lacie! [​IMG][​IMG]
    [Real Men Don't Care About Gas Mileage Or Rapid Tire Wear!]
    Ryan B.
  4. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Welcome to Ck5.
    Are you actually scanning using a scanner or a code reader? Having no codes does not mean all your sensors are working properly (ask me how I know that). My example - had no codes and a cold running problem - turned out to be a manifold air temp sensor was showing 175* at startup in the morning - so you can have a problem without a code. Get a real scanner if you don't already have one (Auto Xray for example for $159) and scroll through all the parameters, looking for what seems out of place. Another thing to check - when you replaced the TPS, did you set it for the idle voltage? My TPI setup requries .54 volts +/- .07, not sure what the reading for your TBI setup should be but it needs to be checked. Let us know what you find and if we can offer more ideas.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
  5. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    I'm with them on fuel pump, I think those are tank mounted, not sure, I have a 72 Blazer, no such thing then.
    Something else to check are the fuel lines. Make sure it is not flattened or pinched anywhere causing a flow restriction.
    The last thing would be is the distributor advance working correctly?
    John
    Like to go sloppin' 'round in da mud in a rapid fashion....=)
    <a target="_blank" href=http://coloradok5.com/gallery/albun31?&page=1>BLAZER PICS</a>
  6. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    Try changing the fuel filter as well.
    Shawnboy.
    <font color=red>If you are having too much fun it's probably illegal.</font color=red>
