New metal for the floor you thoughts?
Discussion in 'The Garage' started by norville, Aug 15, 2006.
  1. norville
    norville 1/2 ton status
    Dec 27, 2005
    268
    A stones throw from Pargon Mountaintop Pa
    Hey folks well I killed any chance of getting my 77 sub running this year. I pulled the carpet back in the cargo area, and yuckko. Looks like it rotted from the top down.
    So I guess I will pull it all out. The supports look and feel solid. I plan to get a sheet of 16-18 guage metal to lay down for a new floor. The wells are good and and the inner walls are good. So I'm thinking get a piece 2" wider and a few inches longer to come up the side a little for welding or bonding and wrap over the front edge.
    Does this sound like a good plan??? Can this metal be bent with a hand tool?? It doesnt need to be pretty just solid. Also, should I rustolium the unded side of it first.
    thanks
    bob
  2. norville
    Dec 27, 2005
    268
    The guy at the shop is talking me into 20guage if I want to bend the lips myself with a hand tool. 6' x 5' is like $70
    bob
  3. 1976Blazer76
    1976Blazer76 1/2 ton status
    Apr 17, 2006
    552
    Ridgefield, WA
    Don't know if you can on a burb, but in my blazer my floors were toast too with the supports still there. So I went out and bought a good looking floor out of a k5 in someones back yard for $50. I cut out mine just enough to leave me 1" all the way around so I had a lip to set the new floor on. I just took my donor floor and put it on top and welded it in. It was nice because I was able to keep my stock holes for the floor and what not. I put over a rubber mat and the thing looks like it was born there. In my opinion it has worked great and I'm very happy with it.
  4. norville
    Dec 27, 2005
    268
    I agree that would be best, but up here there's no way I'll find anything decent. Trust me I don't want to do any more work that necessary. Some of the floore is solid so it might stay but some spots are like newspaper.:(
    I couldn't find pre-bent floors for the burb or I'd spend the money and go that route. if it was under $300.
    thanks for the thought, I'll watch maybe I'll get lucky.
    bob
  5. bluehen
    bluehen 1/2 ton status
    Nov 11, 2004
    215
    DE
    I haven't done the math, but have you checked out LMC?
    And you're right... ain't nothing up here is gonna be worth taking from another truck.
  6. norville
    Dec 27, 2005
    268
    Looked more than once and the numbers just didn't add up. Maybe I'm nissing something or I'm looking at blazer or truck parts??? but I would need the 3 thaey have listed and it still seems short. hopefully someone will chime in thats done this.
    My rear measured ~70" across (or 60" well to wall) and ~ 72" front to rear. I believe they would have fit across but came up short front to rear I'll look again.
    bob
  7. norville
    Dec 27, 2005
    268
    Chevy duty has long bed halfs. that seem reasonable I wonder if they can be cut to fit???
    bob
  8. goldwing2000
    goldwing2000 Guest
    20 gauge steel is like paper. Don't waste your time.
    I'm replacing my rusted-out floors with 1/8" diamond-plate. :D
  9. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Unless you can bead roll it you are gonna need something thicker than 20 gauge. If you can't bead roll it I would use 16 gauge
