New Motor for '89 K5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by njonl, Apr 12, 2005.
  1. njonl
    njonl 1/2 ton status
    Jun 30, 2003
    128
    Northern CA
    My drive an '89 Blazer with what I believe is the stock motor. It is definately tired and Iwant a little more power for towing. I was looking at Jim Pace for GM crate motors. I am specifically looking at the '96 - '00 5.7L Vortec 350. My question is, will I have any problems dropping this in my Blazer ? Will my TBI intake bolt right onto the block along with all the smog accessories ? Will I need to do anything to the computer ? Is there anything else I need to know if I decide to do this swap ? Thanks for any input,
    -Nick
  2. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    I believe you need the following to use any motor with vortec heads. I haven't done it yet, but this is what everyone has told me since I'm researching a GMPP HT383 swap into my '87 350 TBI Burb.
    Intake Manifold GM Performace Parts Vortec manifold with TBI 339.95 summitracing.com NAL-12496821
    Throttle Bracket Universal Throttle Bracket for Vortec Intakes 28.95 paceperformanceparts.com ED8032
    EGR Adapter VORTEC MPFI EGR ADAP MANIFOLD 15.99 paceperformanceparts.com ED2899
    EGR Pipe GM Truck Vortec Engine EGR Pipe 66.73 paceperformanceparts.com 10220275
    EGR Tube Fitting FITTING-EGR Tube, Vortec 6.71 paceperformanceparts.com 12552329
    You'll probably need a custom chip also.
    If you're looking for more performance look into Turbo City's package for TBI Vortec swaps they include a higher flow TB custom chip plus other goodies and run about $1K.
    Or another idea for more horses/torque is Edelbrock's MPEFI for TBI Vortec conversions, this runs about $1K, but includes the chip and intake plus all the MPEFI stuff, so it's a good deal.
    If you still want more power beyond that check out the GMPP HT383, it's built for torque and towing, and is built different than a traditional 383.
    I'm sure someone will chime in with info on they're completed setup, but if not, this should get you started.
  3. njonl
    Jun 30, 2003
    128
    Northern CA
    Mini Mull,
    Thanks for the info. It helps alot. Just curious though, I do have to smog, so all this stuff will still pass smog ? Any idea on what kind of HP/TQ numbers this vortec motor will put out stock ? Also, the 383 you are looking at, does it pass smog ? Thanks again for your input.
    -Nick
  4. mini_mull
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    Tough to say for California. I believe the edelbrock MPEFI for the 87-95 TBIs is 50 state legal, but I'd email them to make sure. I don't think the Turbo city stuff "looks" any different than stock, but I'd email them to make sure. As far as the motor, I believe the HT383 is technically not legal in smogged vehicles(esp CA), but since it's a 350 block and there's nothing to differentiate it from the outside, people in most states get away with it. As far as stock vortec, I would think this shouldn't be a problem since I believe in CA you can go newer, you just have to keep the smog. Keep in mind, all of this info is just what I've heard since I haven't done the swap, and never smogged anything non-stock in CA. I would definetaly talk to a few CA smog refs before changing anything. (I've heard some of them are just like the Capital One comercials and say no to everything, so you should find a good one to work with. I believe there is a smog ref who is a member here, if you search old posts, you should be able pm him with questions. I don't know what the stock vortec 350 hp/torque numbers are, but I know with the Edelbrock MPEFI they claim 265 hp and 340 ft lbs, which isn't to shabby compared to what you have now. The HT383 puts out 340 hp @ 4500 rpm, 435 ft.lbs @ 4000, with 400+ ft/lbs from 2500 to 4000 rpm, but costs around $4K. If you need some retail sites for crate motors let me know and I'll reply back with some, nothing special, but if you're just starting to look it could save you some time.
  5. bigred81
    bigred81 1/2 ton status
    Dec 5, 2003
    323
    Falls City,TX
    I am currently running a vortec motor in my sub with the GM Performance Parts TBi intake to vortec heads. All I had to do was buy the EGR tube and stock vortec manifolds and had the cross over changed to mate with vortec manifolds. I used the stock throttle bracket, EGR valve, and all the other parts that were bolted to the stock intake. You can use your computer with 96-99 5.7 L as long as you use the adapter intake for the stock TBI injectors. Hoipe this helps out some.
    bigred81
  6. njonl
    Jun 30, 2003
    128
    Northern CA
    Mini,
    Thanks again for the informative post. Yeah if you have some retail sites for crate motors that would be great. I am leaning towards the Vortec but I am open to anything.
    -Nick
  7. mini_mull
    Jan 22, 2005
    1,198
    Queen Creek, AZ
  8. mini_mull
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    What vortec motor are you running? I might have some questions for you too.
  9. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    If you plan to install the vortec you will need to do something about the EGR situation like someone else has already said. Also you will need to go to the referee for your first smog since the vortec was never offered in our year blazers, it doesn't really have much to do with it being vortec as it does being that the smog stuff has to be modified so any smog tech is going to send you to the Referee.
  10. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I have seen these selling on Ebay for a while: Vortec TBI Motor
    Looks like a sweet motor. A complete TBI set up including manifold, bored TB, adjustable FPR, and PROM for under 3000 is a good deal.
    I have no personal experience with the company.
    They have been selling those motors on E-bay for a while and have 100% feed back.
    Heres their sitehttp://www.xtremefi.com/ But it looks like they do all their selling on Ebay.
    Might be worth looking into.
  11. Nicks 72
    Nicks 72 Registered Member
    Feb 11, 2005
    64
    Concord California
    Another option that isnt as "sexy" as some of these others is using a gm crate motor for a throttle body Caprice (cop Car) It has a roller cam and my Parts guy says these are now producing about 260 HP. It was well under 2 grand even with sales tax and was actually cheaper then the K motor (truck) throttle body. It looks identical so should easily pass visual and output smog tests and is available locally with a waranty plus everything bolts right up.
  12. K588
    K588 1/2 ton status Premium Member
    Feb 19, 2005
    332
    19
    Westminster,Maryland
    I have been looking at a 383 from Smeding Performance 310HP 420LBFT torque that is a direct replacement for 87-95 trucks and works with the stock computer and is smog legal. www.smedingperformance.com
  13. mini_mull
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    Looks interesting. You'd think it would need a custom chip though, I don't know how they'd get around that. Do you have any charts on it, they don't have any online?
  14. K588
    Feb 19, 2005
    332
    19
    No unfortunately my "looking" hasnt gone any farther than what they have on their web site. it is something I am planning a few years down the road. I believe you can contact them thru the site, it looks to be a nice motor though espically if it would be smog legal.
