New motor mounts install
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by seslick77, Jun 16, 2002.
  1. seslick77
    seslick77 1/2 ton status
    Jan 27, 2002
    220
    Colorado Springs, Colorado
    Is it easier to bolt the mount to the engine and them bolt it to the frame, or drop the engine onto the mounts? Noticed they have a lot of movement when bolting them to the frame. Also are the long bolts that go through the rubber supposed to go through in opposite directions? i.e. one goes in from the rear and one goes in through the front. Thanx /forums/images/icons/grin.gif
  2. YtseJam
    YtseJam 1/2 ton status
    May 19, 2002
    147
    CT USA
    Well I usually install the mounts loose and then instal the engine. Then I install the long bolts and then tighten the mounts to their pads. I believe this helps the mounts last longer.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've always dropped the engine into the mounts. They're pretty much self-aligning once the brackets drop into the mounts.
