new motor...white smoke...WTF!?
Discussion in 'The Garage' started by broncoman6524, Dec 21, 2006.
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    ok theres about 1000mi on my new motor (gm 290hp 350) at idle if yuo look close enough there a bit of white smoke...when you accelerate theres more. WTF? i baby the motor for the first 4-500miles with obviously a totoal of maybe 5xs of actually rompin on it. lol. did i **** something up? or is this normal for a new motor and its just seating the rings?
    HELP!
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Does not sound normal.... Did you change the oil after break-in? What weight oil are you using and can you detect any loss/consumption? Does it puff smoke when you do a cold start?
  3. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Condensation in the exhaust pipes maybe? Is this a mosquito fogger or just a little white smoke? Losing coolant or oil?
  4. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    um there is an oil leak...im pretty sure it came from a loose valve cover. i tighten it down about 15 ago and havent driven since. it would run down the pass side onto the started and fall on the d-shaft adn go everywhere. Its so little smoke that unless you are in neutral and are on the throttle it isnt noticable. it does it both cold and hot. I changed the oil after the first 500mi, havent done it again yet. and i ran 5w30.
    i didnt think about condesation in exhaust...i havent noticed a drop in coolant level...just last night though it went from 60psi oil at 50mph to 45. maybe im just freakin out and being paranoid.:haha:
  5. W7NB
    W7NB 1/2 ton status
    Nov 9, 2006
    716
    Springtucky, OR
    Might be that it's just not broke in yet. I finally had to borax the cylinders on the rebuild in my boat to get the rings to scuff in completely - not for the faint of heart! These new moly rings can take 4-5 k to seat completely. Do check the coolant though! Leaking head gasket could be a baaad thing with the new motor. Did you use torque once head gaskets or do you need to re-torque them perhaps?
  6. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    i bought a long block from gm...i think its a long block. lol bottom end and heads?
  7. PsRumors
    PsRumors 1/2 ton status
    Nov 11, 2006
    626
    Cartersville, GA
    leaking intake manifold maybe?
    Are you loosing or mixing any fluids? If your loosing antifreeze could be intake or head gasket.
    If oil it could be a bad set of rings.
  8. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    i think you might have answered your own question. you said you'd only romped on it about 5 times in the first 500 miles. i stuck a remanned 350 in the k5 several months ago, and they told me to "drive it like i stole it...within reason." it's been a while since i built one, myself, but that's what i basically did. didn't abuse them. i'd go really easy for about 50 miles, then start taking it on short highway cruises 5-10 miles @ maybe 50-60mph. after a few hundred miles of that, it's good. the one in my k5 only puffed for about the first 150 miles.
  9. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    i dont think that sounds normal at all. the only time i have ever heard of white smoke is when your antifreeze is getting into a cylinder some how.
  10. W7NB
    W7NB 1/2 ton status
    Nov 9, 2006
    716
    Springtucky, OR
    Exactly! It's not like the old days when parts were made of softer steel and you had to baby it the first thousand miles.. Chromoly takes a while to break in and seat well. Take er out and wheel her good or take a serious road trip. Watch your oil pressure and engine temp as well as the radiator level. If she heats up going down long grades or you start loosing coolant go home and pull the heads and check the gaskets. Who did the machine work on the heads btw. If they weren't properly decked that could be the problem if you are loosing coolant. Any signs of oil leaks on the sides of the block (other then the *$&@ valve cover gaskets) are also cause for worry.
    Go romp her! Get it broke in and watch it and I think you will be OK.
  11. DaPlumber
    DaPlumber 1/2 ton status
    Apr 4, 2003
    212
    Holland Oh.
    Ok, I dont know why you just dont go back to your GM dealer??? You have a 12 months or 12,000 miles Warranty!!! Why are you runing 5W 30 in it?? The 350ci 290hp calls for 10W 30??
    Crate Engines Start-up Instructions
    1.Always put safety first. If your car is on the ground, be sure the emergency brake is set, the wheels are chocked, and the transmission cannot fall into gear.2.Be sure to check the engine's oil level and prime the oil system.3.Run the engine between 2,000 and 2,500 RPMs, with no-load on the engine for the first 30 minutes.4.Adjust the distributor timing roughly by hand for a quick start-up and the smoothest idle possible. 5.Adjust the carburetor settings, if necessary.6.After the engine has been running for 30 minutes, set the ignition timing (see install ignition section for timing specifications).7.Drive the vehicle with varying speeds and loads on the engine for the first 30 miles. Be sure not to use a lot of throttle or high RPMs.8.Run five or six medium-throttle accelerations to about 5,000 RPMs (55 to 60 MPH), then let off in gear and coast back down to 20 MPH.9.Run a couple hard-throttle accelerations up to about 5000 RPMs (55 to 60 MPH), then let off in gear and coast back down to 20 MPH.10.Change the oil and filter with 10W30SG oil and appropriate ACDelco oil filter. 11.Drive the next 500 miles normally, without high RPMs (below 5,000 RPM), hard use, or extended periods of high loading.12.Change the oil and oil filter again.13.Your engine is now ready for many happy cruising milesCopyright©2003 General Motors Corporation
  12. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    that is almost word for word what my engine builder told me. I am on my 7th year with this motor.
    after all that run the balls of it all you want. and I do.:D
  13. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    i went out and checked my oil bottle...its 10w40
  14. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    run the piss out of it! sounds to me like your rings arent seated yet.
  15. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    10-4 once i fix my carb problems (too rich, and airhorn gasket is cracked bc im an idiot) LOL itll get to play in the mud! WOOHOO LOL
