new motor
Discussion in 'The Garage' started by K5Dan, Dec 27, 2002.
  1. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    im removing old motor.going to put in replacement 350 crate.i have no idea what im doing . anybody in this area want to help.i should have someone to help .if all goes well .the more the merry.
  2. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Get help.Remove the hood,shroud and rad. remove the front wheels and put the rotors on some 2x4s or something to get it down. its a lot easier than it seems, if its an auto you may have to drop the crossover pipe to remove the TC inspecion cover to unbolt the torque converter. 6 bolts hold the block to the tranny. and put a jack stand under the tranny too. one crossblot on each side motor mount. Make sure the trans coller lines are unbolted from the engines oil pan. You should be able too see the obvious stuff, fuel lines wires etc.
