New motor's in, but won't turn over... Help please!
Discussion in 'The Garage' started by Poohbair, May 15, 2005.
  1. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I need someone to help me trouble shoot a wiring problem since I am RETARDED when it comes to wiring. I got the new motor in the Jimmy, got her all hooked up and ready to try and fire... turn the key... NOTHING!!! Anything that is wired direct to the battery works fine... anything that needs keyed power, like the heater, wipers, etc... doesn't work. SOOOOooooo, on the starter the main battery cable goes to the big post, then there are 2 wires that come off of the post and to the cab on the back of the fuse box. They have power all the way to the fuse box. That is where my trouble shooting ability for wiring ends!!! How do I tell if the ignition switch is bad???? Where else could the problem be?
    Thanks for any info!!!
  2. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    First check the fuseable links going to the posts on the firewall just to the left of the brake booster. You should have +12VDC there.
    James
  3. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    fuses getting hot? any bad ones? , or do i need to come over there tomorrow night and figure it out for ya??
  4. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Yes Brad, please come over and fix it for me as I am cHalLenGde when it comes to wiring...!!!!
  5. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I don't think I have any fusable links... my wires just go right from the starter into the back of the fuse box...?
  6. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    yeah there should be a fusible link there, between the alternator and the ignition... it may be on the left side of the engine compartment, on my 73 it is above the distributor on my firewall, but on my 79 it is to the left of the power booster. im having a wiring nightmare currently in my 79... the stupid PO didnt even crimp a wire, he wrapped them around eachother, and covered them in electrical tapE!!!! not fun fixing their mistakes!
  7. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Stupid question, but when you put the motor back in did you also connect the ground strap from the motor to the firewall and from the motor to the battery?
