new mudbogger need advice
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by random, Jul 5, 2002.
  1. random
    random Registered Member
    Jun 12, 2002
    13
    maine
    gettin started in this mudbogger action could use some tips on mods and tires.i have an 84 truck with 350 eng 400 trans np208 case.im runnin dana 44 and 12 bolt with 35 inch wild countrys and 4 inches lift.350 has cam idle to 5500 with performer intake and 600 vac sec carb.the pits we run in vary from 2ft to 4 ft.lookin to go a little further.ty in advance for any info !!!! /forums/images/icons/confused.gif
  2. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    If all this thing is going to see is mud then get some interco Boggers, stiffen up the suspension, get as much HP as you can and go for it. Try to get some headers, good tri-y's not shorties. What gears you running? You don't want to be real low geared in the mud, you need lots of power and wheelspeed /forums/images/icons/grin.gif .
  3. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    When you guys run mud do you put it in 4 low and floor it or do you just put it in 4 high and keep it in first gear?
  4. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    DEfinetly run boggers I run 38.5x11 I run 3.73 gears and 4 lo second gear most pits are 160 to 180 feet long so you won't need to shift. build your motor for torque you will always end up with more horsepower than torque anyways.
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, Boggers are a must.
    Even stiffen up the suspension if you can. If you have softride springs of some kind and do not want to shell out more cash to get some stiffer springs, just add another shock absorber or two to stiffen it up.
    Ground clearance is another issue with mud. Since you mentioned a 4" lift and 35's, why not look into a 6" lift as it will get the bottoms of the frame rails up higher and away from the mud and ground. You don't want to bury the truck to where it will sit on the frame rails.
    Lastly, try to do stuff to keep the engine bay clean. Like install some rubber flaps around areas where water and mud can splash up into the bay. Such areas would be the inner fenders where you can see thru at the exhaust manifold/headers. If you can shield this portion of the frame, you are keeping that much mud/water out of the engine bay. Water on the engine makes it dirtier and harder to work on especially if you have to tune the carb, etc. May want to look at some ideas on waterproofing and sealing up the distributor. Even the HEI's can still get drowned. /forums/images/icons/wink.gif
  6. random
    Jun 12, 2002
    13
    maine
    Hey thanks alot guys!!Suppose i can fit those 38.5s with my 4 inch lift and my cutout flares?Ijust put the 3.73s in before the last run and they worked great,took out 2.73s lol.Think ill have to go 4.11s for the 38.5s?Thanks again for the info!ran 4 lo at last run rpms stayed at 5grand wich worked great.
  7. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    You don't need boggers to play in the mud. What you do need though is all four tires pulling all the time. Install locking differentials in the front and rear. I like the Lock Right cause it is cheap and easy to install. Mine work very well.
    I also have a set of 35" Wild Country mudders, but I also run a set of 38x12.50 TSL Swampers. These work insanely well in almost every terrain. If you do go with a more aggressive tire, I recommend these rather than the Boggers. I think they are a more versatile tire and they tend to last longer as well.
  8. RedDwarf
    May 9, 2001
    816
    Oh yeah, keep those wheels as straight as possible to avoid front axle joint failure.
    You will want to have a fair supply of shafts as they get destroyed when the steering u joint fails. Or just get the chromoly alloy axle shafts and super u joints.
  9. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    How did I know red would beat me up on the boggers yet again I just love mine though red I even have video of a guy set up just like me with the 38x12.50's and I chewed him up but I will go with they will last longer (reg swampers) than the boggers unless you only run them in mud then either will last for a very long time.
