! NEW ! - ORD High Steer Arms......Installation w/Pics!!!
Discussion in 'OffRoad Design' started by Greg72, May 31, 2003.
  1. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    I got the ORD High Steer Arms recently, and just got them installed today. As expected, the quality is awesome and everything fit beautifully.
    Check out the pics here:
    COOL HIGHSTEER!!!
    Thanks Stephen! /forums/images/graemlins/thumb.gif
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    still worries me when ram steer is added....
  3. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    Strength worries or lack of space for the ram itself? /forums/images/graemlins/confused.gif
  4. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    both. the ORD arm look like they can withstand nuclear bombardment, its the stock knuckles that have a hard time. Not a common break, but not exactly an easy trail fix. No spare knuckles in my box /forums/images/graemlins/wink.gif
    edit: I couldn't really see in the pics, but any ideas on where the ram might go?
  5. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    I know what you're saying about the knuckles..... I seem to recall that Stephen mentioned something about his design being less torturous on the knuckles than others (perhaps the fact that they are NOT overly long arms, in fact the DS one is downright stubby! /forums/images/graemlins/grin.gif)
    I've seen the gruesome pics of broken knuckles, but I also "temper" those visuals with the understanding that the folks that ARE breaking those parts wheel a LOT harder than I probably ever will. I haven't spent much time cross-referencing knuckle breakage to the type of vehicle (though I'd be guessing buggy/truggy) or driving style (I'd wager "slow with finesse" wouldn't apply! /forums/images/graemlins/cool.gif) so maybe I might see examples of "Reg-yer-ler old 1-Ton K5s" breaking knuckles on moderately difficult trails...?
    As for the ram, my first guesses are that is will fit beautifully behind the draglink and might attach with a custom bracket off the top of the D60? There was more space around the setup than I was expecting to see, so that is encouraging.
    Now that I don't have a stabilizer anymore (or maybe because the truck hasn't moved in 2 months and the tires are lumpy) there is a wobble in the steering. Not "death", but more than I recall with the damper installed. It's too soon to come to conclusions on this one though.
  6. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    looks dead sexy greg!!!! cant wait till mine get here!!
  7. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    I thought you already DID high-steer?
    Or was that BlaizinAire?....... I know ONE of the tall guys did it! /forums/images/graemlins/rotfl.gif
  8. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    The stress on the knuckle is set by the torque required to move the tire so there's not much we can do about that with the arms. What we can control is the stress on the tie rod by keeping it as far outboard as possible which we did for these arms. Lower stress on the tie rod basically translates into longer life from the ends.
    Interesting things to notice in Greg's pics:
    -Lots of clearance between the spring and tie rod
    -his axle is moved forward about 1"
    Nice pics, thanks Greg.
  9. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    [/ QUOTE ] That was me thank you very much! /forums/images/graemlins/grin.gif
  10. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    Greg,
    Few questions
    -what was the total cost including the shims?
    -why 8* shims? you got a 2 inch longer shackle? and zero rates?
    thanks man.
    Grant
  11. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    Greg,
    Few questions
    thanks man.
    Grant
    Grant,
    The arms are $300...then you add in TRE's, the tie rod, at least one stud kit (two if you didn't already have crossover) .
    The shims had nothing to do with the High Steer. I had 12* of caster due to my custom springs. They are 45" long (instead of 44") and the spring pin is forward 1" over stock. Since that puts the axle further "up the smile" of the spring, the pinion rotates DOWN more than normal.....that's why instead of 6* of caster, I ended up with 12*. The shims allowed me to rotate the pinion back up to around 6* which should give me better street manners.
    BTW -> The front shackles are the ORD ones....the 2" longer shackles I built are intalled on the rear springs. No zero rates at all on Stomper....Mini-Me has a 1" zero-rate in the rear to cure "saggy butt".
  12. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    oh, ok.
    thanks for the info, once again it all looks great.
    Grant
  13. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Hey Greg - The set-up looks great. Have you put anymore thought in how the ram willl mount? Is there enough room to mount it on one of the spring plates? Maybe building a bracket that utilizes the ubolts? Those arms look super beefy! I like them.
  14. CK5
    May 19, 1999
    21,623
    701
    CO
    There sould be room for the ram to mount on the diff somewhere like mine, I will be running these arms also very soon. /forums/images/graemlins/thumb.gif
  15. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    that is sweet!! if any of you have pics of a hi-steer w/ a ram i would love to see them. getting ready to do mine & could use some ideas.
  16. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Hey Greg ..... you gonna be selling your old crossover steering arm?!
    Eric M.
  17. CK5
    May 19, 1999
    21,623
    701
    CO
  18. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    thanks! coloradok5
  19. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    how much lift u have on ur rig again? seems like there would be clearance issues with my puny lil 5" of suspension lift...
    j
  20. CK5
    May 19, 1999
    21,623
    701
    CO
    I run 4" suspension lift in the front. /forums/images/graemlins/thumb.gif
