New Owner '83 Jimmy - Problem Areas?
Discussion in 'The Garage' started by prossett, Oct 10, 2005.
  1. prossett
    prossett 1/2 ton status
    Sep 29, 2005
    165
    United Arab Emirates
    First GMC in my life - awesome beast!
    Before looking at mods, I want to give an overall check - what are the common problems or things that need attention in this model, stuff I should check/change besides oil, air filter, etc?
    1983 V8 305, manual, seems to be in top shape, except for leaking transfer case, heavy and long clutch.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Frame near steering box for cracks for sure . Transfercase for shifting , since its old enough .
    I expect you are going to do some seals like valve covers , transfercase rear seal etc .
    Make it reliable first .
    Everything else on the truck is getting old too , so expect some wiring , switches , and rubber stuff to be replaced as you go :D
  3. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    Check the frame where the steering box mounts. Also top rear shock mounts. Both areas are prone to cracks. Enjoy your K 5.
  4. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    About 6 years agao I had a 81 Blazer that ripped the top shock mount off on the rear drivers side. If you plan to do any wheeling get a frame repair/brace for the steering box mount. Ive seen small cracks in the frame by where tranny/T-case crossmember bolts up. Tho it had a lowered T-case to help driveline angles after lift.
  5. tRustyK5
    Jul 23, 2000
    36,172
    1,381
    E-town baby!
    Swap in a diaphram clutch and your left leg will thank you. Most likely has the 3 finger Borg & Beck style right now.
    Rene
  6. jeeptuff
    jeeptuff 1/2 ton status
    Aug 22, 2005
    158
    Arlington, WA
    front cross member is also a problem area, mine busted to hell along the passenger side, replaced it with one from Mo-Offraod.
  7. prossett
    Sep 29, 2005
    165
    Thanks guys - appreciated, specially since all checks out! No rust, no cracks, no nothing.
    I've greased and oiled all around, and the clutch pedal is a bit smoother now - still long way to get it down though. I'll put the diaphram clutch on the list, maybe for when this one blows.
    My first priority is reliability first, since I drive in the desert and that's a heavy truck to tow out on the sand! From what I can tell and see, it looks like the Jimmy's a solid truck with very few weak spots!!!
  8. ike
    ike Registered Member
    Jul 5, 2005
    96
    orange ca
    steering box mount
    It's good you don't SEE cracks around the steering box mount ......You will need to take the box out to realy check the area...Seach the threads here ...Order the kit and brace for your box from ORD...If its not cracked now....brace it up so it stays that way...Put that at the top of your list..
  9. prossett
    Sep 29, 2005
    165
    Thanks, I'll check it out - excuse ignorance: what's ORD?
    Offroad Racing Design?
  10. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Close... "Off Road Design." They have alot of the stuff you'll need to build yer rig right!! :waytogo:
