new part time idea
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sparky, Aug 22, 2001.
  1. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    I came up with a new idea for a part time "kit" for the np203s. Its too late for me since I already have the Mile Marker shaft kit, but it might save some people some money in the future. We've all heard of lincoln lockers right? (welding the diff. closed in axles) Well, why not apply the same principal to the np203? Is there any way to accomplish that and still be able to get the transfercase out of 4 wheel drive and into 2 wheel dirve. Same principal as the crown gear kit that mile marker offers only instead of wedging the gears together it would weld them together. That would be stronger than the crown gear kit and alot cheaper than the shaft kit. Maybe there is no way to make that work or maybe I am not the first person to think of that, but then again maybe I'm a genious. HAHAHA. What do yall think?
    Sparky
    When all else fails... Check the blinker fluid.
    78 K-5
  2. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    The wedges don't wedege the gears together, they replace them.
  3. Sparky
    Aug 20, 2000
    423
    huh, I could have sworn the crown gears wedged the existing diff. gears. Then again i could be wrong.
    sparky
    78 K-5
  4. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    If you weld it, it will send power to both front and rear axles all the time. With a stock 203, the transfer case acts like spider gears....sending power to either the front or rear, depending on traction. You could do it, but you would have to have manual hubs, and the front and rear driveshaft would be locked together all the time.
    <a target="_blank" href=http://www.moabdadc22.alloffroad.com/>http://www.moabdadc22.alloffroad.com/</a>Real four wheelers don't need tools to remove body panels, paint, tail lights..etc.
