new rear inner hub seals leaking
Discussion in 'The Garage' started by low 84, Mar 22, 2005.
  1. low 84
    low 84 Registered Member
    Jan 4, 2005
    45
    college station, tx
    got the suspension/axles/40's and everything put on this weekend. i'm seeing a little bit of oil coming from the new inner hub seals i put on the rear, it looks like its coming from the between the outside of the seal and the hub, not from between the inner part of the seal and the spindle.
    i am thinking i should have put some rtv around the outside of the seal before putting it in. is that what you guys do?
    thanks
  2. NorthWestFab
    NorthWestFab 1/2 ton status
    Jan 11, 2005
    311
    Canada Eh.
    The compund the seals are coated in (Green on a CR seal) is designed to seal around the outside, but if you have a slight imperfection in the housing, then it wouldnt be hard to leak fluid.
