New rear leafs for my K5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Monster, Mar 5, 2004.
  1. Monster
    Monster Registered Member
    Jun 14, 2002
    68
    New Jersey Warren county
    My 86 K5 blazer Has a 4" suspension lift with blocks in the rear. My blazer sags in the rear because of the stock springs are worn out. I want to replace them with a bigger arch spring to eliminate the blocks. The blocks are angled to aim the pinion at the transfer case. If I put bigger arched leafs with no blocks I am assumeing I will need shims.
    My question is when I by my new leafs will they come with different shims or do I have to by them seprate? If so who sells them /forums/images/graemlins/ears.gif
  2. offroad87
    offroad87 Registered Member
    Feb 2, 2004
    57
    Atoka, TN
    it depends on who makes the springs, some have a little bit of angle on the bottom of the pack and some dont. whoever you get your springs from should also be able to sell you shims if required.
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    My BDS springs had the shim already bolted in the spring pack.
  4. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    I belive superlift also bolts the shim to the spring pack. Or you could alwasy try a shackle flip /forums/images/graemlins/thinking.gif that would point the pinion towards the t-case also.
  5. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Tuff Country rear 4" springs come with the angled shim already. www.offroaddesign.com carries them........... /forums/images/graemlins/bow.gif
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    if you want them to smile alot and also be real flexy then how about having top two or three leaves from a 56" pack rearched and mount them after moving rear hanger back ? if you were not concerned with ability to haul loads
  7. Monster
    Jun 14, 2002
    68
    Thanks for the ingo guys I think I will look into those tuff country springs /forums/images/graemlins/thinking.gif
  8. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    BDS /forums/images/graemlins/waytogo.gif
  9. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Tuff Country /forums/images/graemlins/tongue.gif
  10. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    BDS! /forums/images/graemlins/peace.gif
  11. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Mine too, I think I could use another degree or two /forums/images/graemlins/thinking.gif
