new rig
Discussion in 'The Garage' started by shaun, May 31, 2005.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    Aquired a new rig this weekend.
    86 k30
    8200 original miles
    6.2l NA Diesel
    T400
    205 w/ pto
    D60 4.56 locked (or bad arsh limited slip?)
    14 FF 4.56 detroit
    No rust
    No dents (until the way home got a minor dent when we took it wheeling).
    Will crossover steering from my 10 bolt work on my 60. I know the steering arms are different but will my tierod and draglink work? Also what can you do to make these 6.5's stronger. I would like some power out of her.
  2. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    That year truck should have a 6.2 motor, the 6.5 didn't come in our body style.
    Is it a CUCV?
  3. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Turbo :D
  4. shaun
    Apr 22, 2003
    745
    Yes it is a cucv. It had the giant ambulance looking bed on the back. it said 386 ci so i guess it is a 6.2.
  5. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    Cool, the limited slip (Trac Lock) / PTO versions are rare finds! Good score!!
  6. shaun
    Apr 22, 2003
    745
    trac lok is what s in the front? That is good right? Or should I change it. Also do you know if the crossover steering from my 10 bolt will work on the 60?
  7. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    wow.. 8200 miles... you sure the OD just didnt turn over? They were only 5 digit back then...
    Usually the tell tale signs are there though- Like worn out seats, steering wheel, brake pedal, etc... but if not... you still might need to replace injectors, the truck could have spent its whole life idling!
  8. shaun
    Apr 22, 2003
    745
    No it is only 8200. Whole truck still looks brand new. No cracks no fading. Everything inside and under the hood look brand new. Even the undercarriage looks perfect. It has true duals is that factory? And it has no rust at all. No leaks. Nothing
  9. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    The diesels had duals from the factory :thumb:
    Post some pics, I'd like to see it
  10. shaun
    Apr 22, 2003
    745
    I am working on pics
  11. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Im interested in the 10b crossover if you decide to get a new setup. PM me if you wanna work something out. :)
  12. shaun
    Apr 22, 2003
    745
    I am first curious if it will fit on the 60?
