New Rotors and Pads Question
Discussion in 'The Garage' started by rusty79beast, Aug 31, 2004.
  1. rusty79beast
    rusty79beast Registered Member
    Sep 30, 2002
    64
    Houghton, MI
    Is there a significant advantage to buying the "$50 rotors" compared to the "$25 rotors", and same with all the different priced brake pads from $15 a set all the way up to almost $100 a set? Any help would be greatly appreciated... oh yeah, and these are for replacing the front brakes on my DD 2000 Chev Silverado.
    Thanks a bunch,
    Paul
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I run through the cheap pads quickly , and they squeal too . The perfomance friction types last longer for me and don't make moise . I can't say about rotors , I never bought new ones as mine are still in great shape /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  3. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,175
    132
    Phoenix AZ
    There is typically quite a difference in quality of rotors when going from the way cheap to the moderately expensive units. I'd say look at them both and see what kind of quality differences you can see just by looking at them. Check the two friction planes (where the pads contact the rotor), they should be very similar in thickness. Usually, not always, but usually there will be a significant difference in thickness on the Chinese units as opposed to the domestic produced units usually being rather equal in thickness. I have run both and I now prefer the domestic units.
    Pad quality varies greatly. A good quality (Bendix, Wagner or first line Raybestos) original equipment composition pad should serve you well. For the last 10yrs+ I have used only the Bendix Fleet/Metlock pads and I have never had a noise or excessive dust issue with them, they last a long time and the rotors do as well.
  4. k5mike
    k5mike Registered Member
    Jul 31, 2004
    29
    Houston,Tx.
    Autozone has some that make less dust..the draw back is more metal in the pad "mixture" if you will.....this is harder on the rotors.....yes you can get moderately priced pads that have life time warranties.....but if they make noise and wear out quiker you will be doing more "free" brake jobs...as opposed to wheelin'....drinkin' beer...spendin' time with your family/friends...what ever else you do with your "free" time......just my 2 cents /forums/images/graemlins/waytogo.gif
